Weird ABS Codes
on
Weird ABS Codes
When I was at the track a few weeks back running the 28" inch Dr's my ABS/BRAKE/SLIP/TCS lights came on, I figured it was because the tire diameters are off between the front and rear and after putting on the street tires it'll go away.
Yesterday I finally got my car back from getting the broken axles replaced (see seperate drag racing thread) but the lights were still on.
Performance Nissan replaced my battery because it kept on throwing these codes but the codes are still there.
I brought the car to GTM and Sam read the codes and reset it but no go.
I'm going to bring the car back to him next week to figure this out but was hoping maybe someone here had the same experience and make the research a bit easier.
It's throwing codes like ABS solenoid is not receiving correct voltage (the actual message is similar to this I don't remember it...) and
[C1127]Battery Voltage abnormal (16) and [C1109]Controller Failure (39)
I think there's a [C1110] as well.
It's driving fine but this is obviously worrysome because it involves the brake system.
Any Ideas anyone? (I swear my car is cursed)
on
wanted to add that a buddy of mine and I had to change a wheel stud at the track (rear wheel)(first time either of us did that) could it be that we screwed something up when putting it back together is there a maybe some kind of brake alignment that needs to be done? Since we had to turn the wheel part where the stud goes in in order to fit it in and that is now off?
on
Originally Posted by USN HM 350Z
Did you check your speed sensors? I had the same thing, my right front speed sensor was unplugged and I kept throwing that code. I would reset it and about 1 mile later it would come back on.
Ladrillo (12-30-2022)
on
i have the same problem,i was driving normally yesterday, in the "rain" and out of know where my brake, abs, tcs, and slip turned on, i checked my fluid, its at max, checked all my fuses all were good, the code was c1127 rr rh out abs sol, so i tried changing abs sensors in rear, lights still come on, lights on come on after i start it and start driving. need help cant figure out, someone must have had same problem and fixed it...
Hi, I have a 2004 350Z and all light came on in the dash - TCS, ABD, Brake, etc...Took it to a mechanic and he did a diagnostics and told me that the alternator is good and told me he got the C1140 code... The car starts and drives and brakes fine. Any suggestions please. Thank you!!
11-09-2020 10:27 AM
