question about greddy tt install
Old Dec 9, 2006 | 07:07 PM
huffin-Z's Avatar
huffin-Z
Default question about greddy tt install
im in the process of installing a greddy twin set up and i cant seem to get the bolts on the head studs also the drivers side manifold wont fit in...its almost like the studs are way to long..has any body that has done this had this problem?? would it be a problem to put bolts in instead of the studs?? need help asap
Old Dec 9, 2006 | 09:44 PM
Nic@CiNcity's Avatar
Nic@CiNcity
Do you still have the motor in your car? I JUST got done with my TT install (motor pulled) and some of the studs will not allow your Greddy manifolds to fit properly. You'll need to pull a few out and place them in different spots. I used as many of the studs i could after moving a few around, then added in some bolts as well. I tried to fill every hole, but some are just too tight and had to remain empty.
Old Dec 10, 2006 | 04:02 AM
overZealous1's Avatar
overZealous1
the greddy bolt placement is offset from stock on half of the ports. sounds like you are doing it with the motor in the car. 2 bolts per port is all that is needed, or, will even be attainable on them. thee is a reason they have smaller nuts in the kit!
Old Dec 10, 2006 | 04:52 AM
silver nismo's Avatar
silver nismo
+1 so for a good job get the motor out of the car and get done with it.
Old Dec 23, 2006 | 09:36 PM
tecni's Avatar
tecni
yep, you're actually supposed to take some of the studs out! Read the instructions.
Workshop12
Mar 23, 2020 01:45 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
