Opinion on rev limiter.
Old Dec 11, 2006 | 01:59 PM
sentry65's Avatar
sentry65
the burninator
well i guess what I don't get is especially in the higher gears, it takes a good bit longer to go from 6600-7000 rpms, and how can someone driving the car not notice the flashing light? Also you can usually feel/hear the car is ready to shift, but I know with a helmet on and facing the sun with the windows down it can be hard sometimes
you can set the flashing light to flash at a lower rpm
I believe the light comes on about 500 rpms before whatever rpm you set it to
maybe I'm the only one who has reved to 7000 rpms only exactly when I intended to? Not to say I'd never slip up or be more focused on watching the road or something
But taking corners, you'd never be near the edge of the limiter cause you want to be able to floor it ASAP coming onto the straight without having to shift first
I've seen driving videos though where they're going crazy with the rev limiter. I have no idea if that's an ignition cut or fuel cut though...
If we're talking just one occurance where you bump the rev limiter vs going an extra 300 rpms, then yeah I'd say the limiter is probably the safer bet. I think what I was saying is that I'd rather go an extra 300 rpms than just keep holding my foot down while on the rev limiter bouncing off it multiple times in a row. Even in some video games doing that will hurt your engine
Originally Posted by sentry65
It can cause a lean condition since fuel is cut and overheat things if you just sit there bouncing off of it all day
Old Dec 11, 2006 | 04:17 PM
redman333's Avatar
redman333
I understand that if I raise the limiter and most of the time I don't hit the limiter, and try to still shift at 6600(which is my case) and that one time they go past the 6600 and had the limiter raised in turn didn't hit the limiter and not causing a strain on the engine. But what about that one time I go past the 6600 and still rev up to hit the rev limiter that has been raised. Now you have the added stress of the already raised limiter and now the fuel cut.
I know this isn't good for a stock bottom(I found out the hard way too) but is it still bad for a built bottom end.
I actually agree completely with alberto, he's also been doing this longer than me. But on stock internals.
Old Dec 11, 2006 | 08:33 PM
Chako135's Avatar
Chako135
...would you guys agree with the fact that raising the rev limiter to 7K
still has the potential to damage the motor even if you dont have a FI setup?
Old Dec 11, 2006 | 10:50 PM
silver nismo's Avatar
silver nismo
Originally Posted by Alberto
On a stock motor DO NOT RAISE your limiter, leave it at 6600rpm's. Inertial loads increase by something like 45% from 6000 to 7000rpm's. I ran a raised limiter in my TN and only used it for 1st and 4th gear. 3000 miles later---->rod failure, dont do it!
+1 man we get cams shims and springs to rev 7000/7500 and u r reving 7000 on stock take care man u want to build ur engine not buy a new 1 and build it coz this 1 is Fuct.
Old Dec 11, 2006 | 10:52 PM
silver nismo
Man if u r an FI well a good build FI fuct it u can rev 8000 on 1st and 2ed if u want but the point i want to tell u that u got it the other way arround....
ok so if u r a build FI u can if u r not a build FI or u r still NA dont do it.
Old Dec 12, 2006 | 05:23 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I ran the 7100rpm NA with a Techno flash, never had issues NA, but the Q is, did it prematurely cause something to fail later with boost? We wont know, although I wouldnt be scared running this NA again....
wanderingstuden
Jan 28, 2016 07:03 PM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
