Philthy's Base Tune Completed...
Old Dec 19, 2006 | 08:18 AM
Philthy's Avatar
Philthy
Boost Junkie
Originally Posted by MRC Motorsports
So it made about 550whp on 16.5 psi then correct?
Just let me know when you'll be around and I'll shoot down with the car... We can run your car on the dyno and then mine immediately after, now that would provide a great comparison...
Old Dec 19, 2006 | 08:22 AM
Philthy's Avatar
Philthy
Boost Junkie
I'm sure I miss a bunch of items, but here is a pretty much complete breakdown on the engine and drivetrain.
-Weston Machine Spec’d Darton Liners
-Wiseco 9:1 .020” Over Pistons
-Pauter Rods
-Cometic Head Gasket
-ARP 1/2” Head Studs
-ARP Main Studs
-Ported/Polished by Headgames Motorworks
-JWT Cams
-Ferrera Valve Train
-PE TT Kit with Cast Manifolds (Upgraded Turbos to Garrett GT28 Series)
-Rev-Up Oil Pump
-HKS DLI II
-HKS BOV
-HKS F-CON V Pro
-HKS Harness
-HKS Pressure Sensor
-HKS Air Intake Sensor
-HKS Pressure/Air Intake Sensor Harnesses
-HKS Pressure/Air Intake Sensor Mounts
-HKS A/F Knock Amp
-HKS O2 Sensor
-Technosquare Reflash
-Blitz Boost Controller
-3” Dual Stainless Exhaust with Magnaflow Race Mufflers
-ACPT Carbon Driveshaft
-Power Enterprise Oil Pan
-Setrab Oil Cooler
-Nismo Trans Cooler
-Nismo LSD With Diff Cover
-DriveShaft Shop Level 5 Axles
-Crawford Plenum
-RC Engineering 1000cc Injectors
-Defi Gauges (Boost/EGT/Oil Pressure)
-AAM Stage 1 & 2 Fuel system with CJM Upgrades
-CJM Crank Angle Sensor Wire
-Koyo Radiator - Race
-Nissan VQ35 Rear Coolant Bypass System
-Nismo Thermostat(s)
-Samco Hoses
-NGK Plugs
-ATS (Carbonetics) Triple Disc Carbon Clutch
-Steel Braided Clutch Line
Old Dec 19, 2006 | 08:28 AM
Julian@MRC's Avatar
Julian@MRC
Soon as we get a new monitor for the DYNO, we had a little accident at the shop and took out the Dyno screen
Old Dec 19, 2006 | 08:34 AM
Philthy's Avatar
Philthy
Boost Junkie
I tell you what - I have a brand new monitor I'll provide to you as a gift, and you comp my dyno runs, deal?
Old Dec 19, 2006 | 08:40 AM
Julian@MRC's Avatar
Julian@MRC
Deal..
Also ask don to bring some cans of C-12/C-16 gas, we need to buy some from him, were all out right now..
Old Dec 19, 2006 | 08:45 AM
Philthy's Avatar
Philthy
Boost Junkie
Deal..
If you want to fill up on VP 103 just stop by my house Send me a PM with how much C12/C16 you want, I'll stop by and pick them up.
Old Dec 19, 2006 | 09:25 AM
Julian@MRC's Avatar
Julian@MRC
k
Old Dec 19, 2006 | 11:26 AM
dutchboy's Avatar
dutchboy
Philthy, do you have a dyno printout that reads beyond 6,500?
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I believe the peak number was 572whp...or right in that range...at 16.5psi. Trq was a hair over 600ft/lbs. The smallish downpipes are causing some backpressure issues.
Old Dec 19, 2006 | 11:28 AM
Sharif@Forged
Forged Performance
The engine didnt make anymore past 6500rpm, so Jeff set the dyno run to stop at 6500rpm. The DynoPack has several run parameters that need to be set, so we just left the ramp time at 10 seconds, and the run started at 2200 and the run stopped at 6500rpm.
Old Dec 19, 2006 | 11:31 AM
dutchboy's Avatar
dutchboy
Thanks Sharif. That's alot of power from 5,500 to 6,500 rpms, not much drop off at all.
Old Dec 19, 2006 | 11:43 AM
Philthy's Avatar
Philthy
Boost Junkie
Given that the car only had 150 miles on the motor, and we detected a backpressure issue with my 2.5" down pipes, we all agreed that safe and conservative was the best route at this stage.
I've got to be completely honest, I drive a 480+whp STI every day with no drama, this car is just plain nuts in first, second, and third gear and I need a lot of time before we start shooting for more power.
Old Dec 19, 2006 | 08:18 PM
HeadGames's Avatar
HeadGames
that's a bad *****..can't wait to see it! Thanks for letting headgames be apart of it
Old Dec 22, 2006 | 03:10 PM
mraturbo's Avatar
mraturbo
Very nice.
Happy Holidays.
M
2ndchanceZ
Oct 26, 2015 08:03 PM
350z82
Oct 1, 2015 06:25 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
