Question about engine rebuild
Old Dec 26, 2006 | 05:27 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by Eazzzzzzy
No need for me to use ur Quote Todd----I missed that as I was typing that last post ---But thats interesting ----Theres a lot that is new to me as far as very late model engines.
One thing I was curious about was the Balance procedures with the Z motors---------Is it still, weighing Crank pulley ,rods,pistons,rings,pins,flywheel etc. ???? And then removing metal to acheive Balance
weighing the rotating assembly: rod, piston, rod bearings, rings, piston buttons (in the case with the ED arias), then building bobweights, attaching to each crank journal, then spinning crank...
evry crank we have checked has been at least 3-18 grams off each side..the balanced product is to less than .5 grams!
Old Dec 26, 2006 | 05:33 PM
Eazzy's Avatar
Eazzy
Sorry --My posts were getting out on sync with urs----Thats great and its not overkill ---Its the way it needs to be done.
I relize the Piston to Wall clearence has tightened up as far as Cast Pistons and Forged but didnt know how much.
There was a time that a properly clearanced Forged piston sounded like a can of rocks till it heated up
Old Dec 26, 2006 | 05:35 PM
Eazzy's Avatar
Eazzy
Excellent ---Thanks
Old Dec 26, 2006 | 06:55 PM
350Zzzz's Avatar
350Zzzz
Professional
Originally Posted by Cannysage
when you guys get your engine rebuilt, they put in an engine that they've already built, right? How do you know if the engine isn't some previously blown pos, with 100k miles on the block, that's been rebuilt? If your new car's got only 5k on it, wouldn't you rather rebuild your own?
There is really not much you can do except check the VIN # and the more reason you want to deal with someone you know or comes strongly recommended. You have quite a few options available, shops that have been tried & tested; and supported by many on this site.
Using your own block, that is if it is usable, would mean a longer turn around time, and depending on what you wish to do.
G
________
liqalu04
Jan 2, 2022 12:58 PM
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
