** Aps Extreme Tt Kit Install **
Old Jan 14, 2007 | 02:15 PM
  #41
Gators2001's Avatar
Gators2001
Just Put new tires on. Damn those old ones where dead!
Now I can acctually get some grip.
Hopefully, I can get to Japtrixs this week to turn the boost up and see what this puppy can do.
After that, Take her to moroso and see how I perform.
Old Jan 14, 2007 | 02:25 PM
  #42
masterj26's Avatar
masterj26
what tires did you switch to?
Old Jan 14, 2007 | 02:53 PM
  #43
Gators2001's Avatar
Gators2001
they are black and soft.
BFG DRs
Old Jan 14, 2007 | 04:47 PM
  #44
350Zzzz's Avatar
350Zzzz
Professional
Originally Posted by westpak
Sorry no big fonts and bells and whistles on this post just wanted to post info on an install of an APS Extreme TT kit along with a built block in forum member Gators2001's 350Z. Very nice kit, the intercooler is huge, for the engine management we went with a Utec.
Other mods previously installed or installed along with the kit and built block:
JWT Springs and C2 Cams
HKS Headgaskets
ARP L19 Head Studs
Samco Hoses
Nissan Rear Cooling Mod
KOYO Slim Radiator
JWT Flywheel
Clutchmaster FX400 CLutch
TurboXS Utec and Tuner Pro
Sertrab Oil Cooler
APS 3" Exhaust
AAM Plenum Spacer
The car was tuned for base boost of the wastgates which turned out to be 12 psi, we will tune for higher boost later. Results on our Mustang dyno were RWHP=476 and RWTQ=411, he took it to a Dynojet and got RWHP=507 and RWTQ=442. I am sure he has his hands full with that but will bring it back in for a higher psi tune.
Very nice pictures, Gus; I love it when someone makes the effort to detail pictures of the VQ & install.
Most appreciated...thanks
G
____________
Old Jan 21, 2007 | 05:12 PM
  #45
Gators2001's Avatar
Gators2001
Turned up the boost this weekend.
We got 550+ HP and 530+ TQ on 18 psi. When adding 50% race fuel we were able to get 20+ HP out of her. This was done in forth on a Mustang Dyno in 78 degree weather.
Thinking something is holding her back.
Took her to the track also and my poor skillz only got me a 12.9 at 124mph.
I didnt hook up till 3rd. 1/8 was like 8.9
I need lotz of practice.
I have to say this has been a great experince and want to send out a BIG THANKS to Gus and ROGER at Japtrixs!
Anyone know any respectable DynoJets in the Broward/WestPlam area?
Old Jan 22, 2007 | 05:32 AM
  #46
dutchboy's Avatar
dutchboy
Was the 550whp with the race gas, or did you make 570whp on race gas? What was the deciding factor on keeping the boost at 18psi, was it running out of fuel? I would have thought at 18psi, you would have seen a little more hp, but 550whp is still pretty nice.
Old Jan 22, 2007 | 06:03 AM
  #47
Gators2001's Avatar
Gators2001
Yea thats why we didnt go higher, we did one run with 20 psi but didnt see a difference. We were in the 540-550s all day on pump gas even at lower boost, but with the 2+ hours of tuning I didnt want to say 15 and it was actually 17. I remembered getting like 557 on 18 psi so I went with that one.
Our next step is to find out was the car getting heat soaked, hit the limit of the heads, or is it something else I over looked.
Also remember these #s are on a mustang dyno which ppl say could be around 10% lower and done in fourth. On my car I have seen as much as a 15 hp lower in fourth, opposed to fifth. But every dyno is different so I'm gonna wait to see if we can find the limiting factor before taking her to a dynojet again.
Dont get me wrong, I love these numbers. I also expected more from that PSI level. But if it wasnt a challenge, it wouldnt be that much fun.
Old Jan 22, 2007 | 06:22 AM
  #48
dutchboy's Avatar
dutchboy
You're right, either way those are big numbers, and it must be a blast to drive. It'll be nice to see how my numbers come out, we have very similar builds. I would'nt be at all surprised if you see 10-12% more from the Dynojet, that's what I've seen locally when going from the Mustang to the Dynojet.
Old Jan 22, 2007 | 06:33 AM
  #49
brooke's Avatar
brooke
I thought the extreme kit came with 50lb per min turbos meaning 1000 flywheel hp max with 17% drivetrain loss, would be alot higher than that.. ?
Old Jan 22, 2007 | 07:22 AM
  #50
sabrefanpc's Avatar
sabrefanpc
is traction more or less ruled out as the problem then?
Old Jan 22, 2007 | 07:24 AM
  #51
masterj26's Avatar
masterj26
hopefully that is what it is
Old Jan 22, 2007 | 11:11 AM
  #52
westpak's Avatar
westpak
SFZCC
Well there are a lot of other factors that come into play not just what the turbos can or are capable of doing just look at the single turbo kits.
We need to look at other things and mainly air flow, the heads are basically stock heads, it has the stock 287 HP lower plenum and an AAM spacer, maybe a 300HP lower plenum with an APS upper plenum will help maximize the airflow through the plenum and into the runners without going to a plenum like the SFR plenum which flows right into the runners.
Also looking at port and polish of the heads, as well as oversized valves and a 3 angle cut on the valves.
When you get to this level trying to get the most out of a kit you have to look at all of the little details and decide how far you want to go and how much to spend it is not just sticking big turbos on.
Old Jan 22, 2007 | 12:30 PM
  #53
Gators2001's Avatar
Gators2001
I wish there was a try then buy policy on some high quality heads...
Gus we need to go out for dinner with Roger and figure this puppy out!
*Traction*
I think my Fat AZZ solved the problem for the time being. (w/ DRs)
Next Im gonna need slicks to dyno her.
Old Jan 22, 2007 | 12:53 PM
  #54
sabrefanpc's Avatar
sabrefanpc
hehehe. i took that picture, just figured i'd let you be the one to post it.
