help obd codes inside
Old Jan 18, 2007 | 12:51 PM
kostat26's Avatar
kostat26
Default help obd codes inside
my car stopped working right after an alighment was performed(long story).... the gas pedal wont work normal one sec it works the next it loses all power...heres the codes i got out of my car if anyone can help me out. i also dont have cats so some of them might be cat related
P0603 Internal Control Module Keep Alive Memory (KAM) Error
P0463 Fuel Level Sensor Circuit High Input
P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P1168 FRP Sensor In Range But Low
P0081 Intake valve Control Solenoid Circuit (Bank 2)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P2135 Throttle Position Sensor
Old Jan 18, 2007 | 01:16 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
That's a pretty fuct up list of codes. What troubleshooting steps have you tried so far?
Old Jan 18, 2007 | 04:22 PM
failsafe306's Avatar
failsafe306
Damn sounds like they cut and/or shorted some wires out! I don't know how they possibly could have though....
Old Jan 18, 2007 | 04:24 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
or maybe a hrness is disconnected.
Old Jan 18, 2007 | 05:18 PM
Dirty Dave's Avatar
Dirty Dave
Maybe when driving the car up on the lift or using the wrong jack points they pinched some wire harnesses ???
Old Jan 18, 2007 | 06:21 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
make sure that it wasnt a coincedence and maybe melted through some wires in the wire harness at the same time as the alignment for some reason, lots of wires run close to hot items.
thats where i would start man...
Old Jan 18, 2007 | 06:58 PM
kostat26's Avatar
kostat26
i put a new fuel assembly jsut cause mine was kinda sloppy. and i reset the ecu it runs fine for likr 5 minutes then the pedal and rpms dont work it jsut drops and i floor it wil go up super slow
Old Jan 18, 2007 | 07:13 PM
kostat26's Avatar
kostat26
i found this 2 harness disconnected under steering wheel. i tryed to search to see where they could possibly go couldnt find another end and they dont connect with eachother...?
Old Jan 18, 2007 | 07:34 PM
westpak's Avatar
westpak
SFZCC
First I would try and clear the codes with a scanner or Cipher, some of those may be left over from the install and then see which ones come back.
It seems like a lot of signals not getting to the ECU and causing it to go into Safe Mode.
Check the Unichip harness connection to make sure the plug n play harness is properly plugged in, and then also check the actual wires going into the Unichip harness to make sure none are lose.
Also check for any melted wires, specially around the crossover pipe, if you didn't heat wrap those that might be your answer.
Old Jan 18, 2007 | 07:39 PM
kostat26's Avatar
kostat26
i checked for melted wiress on top of cross over pipe nothing and the pipes are heatwrapped also.. im gonna try more things tommorow didnt have time today cause i had to go to work to check everything
Old Jan 19, 2007 | 07:50 AM
kostat26's Avatar
kostat26
http://s22.photobucket.com/albums/b3...=103006027.flv
heres a lil vid after i reset the ecu. i drove for 4 miles and then the pedal jsut stopped responding... my wideband seems low, maybe cause i had lil fuel. no melted wires i checked the harnesses everything seemed fine i checked the unichip seemed fine...
Old Jan 19, 2007 | 11:38 AM
kostat26's Avatar
kostat26
Bump
Old Jan 19, 2007 | 02:39 PM
failsafe306
Like I said in IM, those two plugs on my '03 are hooked up to the brake and clutch pedals. Try to get it to the dealer.
3vilbunny
Jul 18, 2017 05:10 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
