Greddy TT ppl w/ or w/o Fuel Return Systems
Old Jan 19, 2007 | 01:28 PM
evimero350's Avatar
evimero350
Default Greddy TT ppl w/ or w/o Fuel Return Systems
Ive done my searching all day here at work and Im still fighting myself.
Im going to be installing a Greddy TT kit with UTEC and Walbro 255 and going to Sharif at Forged to get tuned for a daily drivin 6 psi.
Now staying with the Greddy 440cc injectors and having goals of 350-380whp at 6psi SHOULD I get the AAM Fuel Return System?
From searching I found out that most ppl are advised if having goals 400+ to equal out pressure to all injectors, but I have different goals, so what do you guys think?
Old Jan 19, 2007 | 01:30 PM
BoOsTedz33TT's Avatar
BoOsTedz33TT
no fue system, i make 453
Old Jan 19, 2007 | 01:43 PM
phunk's Avatar
phunk
CJ Motorsports
at 6psi its not really needed, but i think you might be surprised at how quickly you will become bored at 6psi when you know that 7+ is only a turn of a **** away it wouldnt be a bad idea to have it as a sort of "overboost protection" either, just to help your odds if you accidently overboosted.
Old Jan 19, 2007 | 02:04 PM
VIZAGE's Avatar
VIZAGE
All I'm going to say is if you decide to go return fuel system go with the CJM system. Many will say it's better.
I'm also up in the air about what to do at 8psi (on TN kit). I think I'm not for now unless the fuel pressure is to high, then I'll go that route no ?'s asked.
Old Jan 19, 2007 | 02:22 PM
Oleg's Avatar
Oleg
Look at all the TN people running around at 400whp on 9PSI with just the walbro and 380cc injectors.
FWIW, AAM has a 500$ fuel return kit which uses stock rails...
Old Jan 19, 2007 | 02:36 PM
QuadCam's Avatar
QuadCam
I had a fuel pressure problem and was not sure what it was.......many people said it was probably the stock fuel rails/lines/regulator. At that point, I manned up and bought a custom setup from CJM for my sedan. CJM is the only one who makes a sedan fuel system. It turned out that my walbro pump was the problem, but now I have my CJM fuel system and I love it. Actually, I wouldn't have been able to predetermine that my pump was bad if I didn't have the return system.
No fuel smells.
Hot starts are perfect (used ot be a problem before the CJM setup.)
Great customer support, too!!
Old Jan 19, 2007 | 02:56 PM
Jokestrap's Avatar
Jokestrap
I was at 421whp w/o fuel system and it was fine.
Old Jan 19, 2007 | 02:57 PM
BamBam's Avatar
BamBam
You don't need a fuel system at that power level.. BUT when you want to turn up the boost you should look into CJM's fuel system.. They got some really high quality stuff and you won't get any gas leaks or fuel smells....
Old Jan 19, 2007 | 02:59 PM
roncfpz's Avatar
roncfpz
I think you should just follow Sharif's advice.
Old Jan 19, 2007 | 03:53 PM
carlosG's Avatar
carlosG
life starts at 16psi whooa
Old Jan 19, 2007 | 04:00 PM
doug's Avatar
doug
he hasn't posted in this thread
Old Jan 19, 2007 | 06:44 PM
roncfpz's Avatar
roncfpz
But he said Sharif is tuning the car. Why not follow your tuner's advice?
Old Jan 19, 2007 | 06:52 PM
doug's Avatar
doug
ahh.. didn't read that part
Old Jan 20, 2007 | 08:22 AM
evimero350's Avatar
evimero350
Cool I appreciate it guys! I didnt know AAM made a kit for the stock rails? Seems like most people get the one with the free-er flowing rails still.
Old Jan 20, 2007 | 11:26 AM
phunk's Avatar
phunk
CJ Motorsports
Most people dont like the stock rails because they have a small feed pipe attached to them and they run in a series rather then parallel.. both of which run you risk of pressure drop across the rails and uneven cylinder tuning.
If anyone has that kit that runs the stock rails and starts pushing 450+ thru them - I would recommend also purchasing their fuel pressure gauge tap and running a gauge in your regulator port and your tap port and video tape both gauges during a dyno run to verify the pressure is holding up equal at both ends.
sales@czp
Sep 23, 2019 03:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
