vortech pulley change
Old Jan 20, 2007 | 12:34 PM
Bwicked's Avatar
Bwicked
Default vortech pulley change
Going from 3.12 to 2.87 tomorrow.
Same belt size can be used correct??
I have TWO main questions
1) Can someone Show me a diagram or a HOW TO or tell me of removing the 3.12 and installing a new pulley?
2) Can someone show me or tell me how to tighten or loosen the belt?
I'd like to do this tomorrow, please someone chip in
Old Jan 20, 2007 | 01:41 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
You cannot use the same belt. To loosen the main belt loosen the tensioner on the pass. side. You'll have to do it from under the car. You'll need a 12mm and an extension. Also need a 14mm to loosen the bolt that holds the pulley on. Don't take it all the way off, just loosen it a little. I also think you need to pull the blower and bracket off to swap pullies. IIRC.
Old Jan 20, 2007 | 01:42 PM
booger's Avatar
booger
the 3.12 and 2.87 take the same 93 inch belt
Old Jan 20, 2007 | 01:43 PM
Bwicked's Avatar
Bwicked
Do u know what belt I need? part number?
also where is the tensioner located?
Old Jan 20, 2007 | 01:52 PM
booger's Avatar
booger
look it up in the manual or do some searching here . Go to Napa and ask for a 93 inch serp belt
actually..lift your hood up and look at the pic that shows the belt routing . That should show you where to losen it up at .
Old Jan 20, 2007 | 01:56 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
my bad, I guess there's enough adjustment to cover the difference in the tensioner.
Old Jan 20, 2007 | 01:59 PM
booger's Avatar
booger
I tried a 92.5 and couldnt get it on
Old Jan 20, 2007 | 10:12 PM
imalazeeass's Avatar
imalazeeass
looks like u got my package pretty fast congrats
Old Feb 19, 2007 | 09:00 AM
Big Blue's Avatar
Big Blue
I have the stock setup that comes with the vortech. I am going from the 3.3 to the 2.87. What issues will I have and what should I change besides the belt. A 93 I gather. Thanks.
Old Feb 19, 2007 | 09:05 AM
sentry65's Avatar
sentry65
the burninator
injectors and fuel pump, possibly fuel system
lapham3
Oct 7, 2022 03:15 PM
Fixxxercask
Nov 9, 2015 11:10 AM
