Boost control (overboosting)
Old Feb 2, 2007 | 05:05 PM
MIAPLAYA's Avatar
MIAPLAYA
Scanner wasn't feeling it but here's Part 2 of the Modified Mag article. Couldn't find part one.
http://turboneticsownersclub.com/turbos/knockoffarticle
Old Feb 2, 2007 | 06:05 PM
JETPILOT's Avatar
JETPILOT
Does this help?
JET
Old Feb 3, 2007 | 11:51 PM
znot's Avatar
znot
jet,
looks like you're using braided lines for the oil return, if you don't mind, what necessary parts are needed? i'll be installing the tn st kit soon, i don't feel too comfortable with that rubber hose for oil(hot oil) return......thanks.
Old Feb 4, 2007 | 01:19 AM
JETPILOT's Avatar
JETPILOT
I posted this thread not too long ago. The parts posted in this thread are for return to the upper oil pan as per the Turbonetics directions. The drainline there has been replaced with an Earls -10AN nylon braided hose. The metal braid was eating into my sway bar. If you go with an AAM oil pan spacer for your oil return it comes with all necessary fittings.
https://my350z.com/forum/showthread....ics+accesories
JET
Old Feb 5, 2007 | 03:11 AM
silver nismo's Avatar
silver nismo
Originally Posted by MIAPLAYA
If you install the overboost pipes it should take care of this anyways... But if you want to be extra sure you can switch wastegate springs to a 5 PSI or 7 PSI spring and run a boost controller of your choice to bring the boost to where you want it.
+1
Old Feb 5, 2007 | 08:25 AM
znot's Avatar
znot
JET
thanks...
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
codek
Sep 28, 2015 03:03 AM
