9 psi. pulleys
Old Apr 26, 2007 | 01:38 PM
  #41
eltness350's Avatar
eltness350
The Untouchable
440 for sure
Old Apr 26, 2007 | 02:25 PM
  #42
atlg3503's Avatar
atlg3503
Would I also need the walbro pump? Thanks for all the info.
Old Aug 16, 2010 | 04:54 PM
  #43
zcar03's Avatar
zcar03
How many teeth are on your 9lb pulleys I keep getting conflicting numbers.
Old Aug 17, 2010 | 09:56 AM
  #44
brotus's Avatar
brotus
That was an old post you brought back but, here's the info: 9lb=26/39
Old Aug 17, 2010 | 03:30 PM
  #45
zcar03's Avatar
zcar03
Damn I have 40/25 I bet thts close right??
Old Aug 18, 2010 | 07:00 AM
  #46
brotus's Avatar
brotus
The 7lb pulley is 27/38. So, it looks like you have the 12lb pulley ( I think that is the next step up but, I not sure )
Old Feb 13, 2011 | 08:24 PM
  #47
Zquicksilver's Avatar
Zquicksilver
as do i... i must not be doing the right search!?
i thought 26/39 = 7lb and 24/42 = 10lb
is there a formula per ATI that i missing for each individual setup?
any actual procharged guys want to chime in with what they actual have or what pullies (24/42) equal approx. (x) boost?
Zquicksilver
Old Feb 14, 2011 | 03:11 PM
  #48
superchargedg's Avatar
superchargedg
Damn Noobs
Holy old thread revival.
Old Feb 15, 2011 | 11:02 AM
  #49
Zquicksilver
thanks for the bump and it's better than having to suit up in a shiny outfit to ask some pully questions in a new thread
so... what does a 24/42 cog teeth Procharged pully = in terms of lbs. or approx. boost?
Thanks,
Zquicksilver
Old Feb 15, 2011 | 03:12 PM
  #50
str8dum1's Avatar
str8dum1
boost is a measure of backpressure and nothing else. it can range for 7 to 12 psi depending on your heads, cams, exhaust, compression ratio etc....
Old Feb 15, 2011 | 08:11 PM
  #51
snobes's Avatar
snobes
This is true, but procharger named it's pulley upgrades as 9psi, 12psi etc assuming a stock engine and not a xxteeth pulley etc
Hence the question.
Old Feb 16, 2011 | 10:11 AM
  #52
Zquicksilver
thanks STR8... it does make sense. i'm referencing a procharged kit that was on stock compression, stock headers, TP's and a large single exhaust and the guy was trying to get the SC to hit 10psi. ATI gave him a 24/42 pulley set... IIRC, he hit 10psi.
so... per EP3
"sorry to bring this back, im having the same problem. i searched and got many different answers i just ordered the "9psi set" from a vendor here and it came with 3 pulleys, the third being the one you need to remove the flange from on the back of the blower a 28tooth. i thought you only have to change the front 2? the numbers on the puleys are 25 / 40. i called procharger prior to ordering directly and asked what tooth count all the pulley sets were and here is the anwser i got from their tech line (7 psi - 27/38) (9 psi - 26/39) (11psi 25/40)"
Zquickslver
Fixxxercask
Nov 9, 2015 11:10 AM
NissanZcrazy
Sep 23, 2015 07:59 AM
Calinismo350z
Sep 14, 2015 04:04 PM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
