Idling Issues/surging with sc?
Old Feb 16, 2007 | 10:12 AM
TXAGGIE's Avatar
TXAGGIE
Default Idling Issues/surging with sc?
I recently bought my car with everything on it. When it idles at around 750 when warm it seems to sometimes surge and drop below that and then pop back up. when it does this it makes a bobbling noise that kinda shakes the car. i was told that it is the tensioner pulley that is doing it but i dont understand why the idle is dropping like that. anyone else have this problem or any advise? i guess it could just be the tune...Thanks, Jason
Old Feb 16, 2007 | 10:24 AM
ANXIOUZ's Avatar
ANXIOUZ
The stock idle is inconsistent. Mine does exactly what you describe so I had it raised to 800-850 and it helped. But it still isn't a rock-steady idle.
You might want to have your idle bumped up a bit. That should help if it's not related to the sc.
Old Feb 16, 2007 | 11:09 AM
singh's Avatar
singh
_______________
Did you consult with SGP?
Old Feb 16, 2007 | 12:12 PM
drifter23's Avatar
drifter23
I have the idle issue on my Vortech 2004.5 350Z. My tuner used a consult 2 to help the idle from moving up and down. It helped a little but, my idle still moves a tad. I'm going to have him take a look at it again sometime next week. The dealer can also help you with your idle but, they charge like $80 to do it. If any of you found a fix for it please post it up. If I find the fix I'll post it up on the thread. Thanks in advance.
Old Feb 16, 2007 | 12:21 PM
ANXIOUZ's Avatar
ANXIOUZ
The fix is to use the Cipher software to raise it.
Old Feb 16, 2007 | 02:25 PM
drifter23's Avatar
drifter23
Any info to where I can obtain the Cipher software.
Old Feb 16, 2007 | 02:33 PM
ANXIOUZ's Avatar
ANXIOUZ
Google sent me here: http://www.alteredatmosphere.com/mm5...tegory_Code=FX
Your best bet is to post in your local area forum and ask around. There were like 3-4 guys in my area that all offered to do it for free. One of the guys brought his laptop to a Z meet and took care of it in 2 minutes.
Old Feb 16, 2007 | 02:56 PM
drifter23's Avatar
drifter23
Thanks for the info ANXIOUZ. The CIPHER Diagnostic tool is just like the Consult 2. Cool item and priced pretty well to. Very odd how the Consult 2 didn't fix my idle. Gonna see if anyone in my area has this and give it a try.
Old Feb 16, 2007 | 07:10 PM
TXAGGIE's Avatar
TXAGGIE
thanks for the info guys...
Old Feb 16, 2007 | 08:03 PM
QuadCam's Avatar
QuadCam
check for small vacuum leaks too.
Old Feb 16, 2007 | 08:52 PM
Enron Exec's Avatar
Enron Exec
Check for a cut, causing a boost leak, under the flex pipe right before the straight intake pipe to your throttle body.
If that is the problem, replace the flex pipe and but some edge guard on that sharp metal corner.
Whoop Fighting Texas Aggies!
Old Feb 17, 2007 | 11:54 AM
booger's Avatar
booger
Unless you have cams . Your idle shouldnt be any different than it was stock . The cause could be a lot of things , but a vacuum / boost leak would be a good place to start looking .
liqalu04
Jan 2, 2022 12:58 PM
05UltraYellow
Sep 24, 2015 05:41 AM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
Darkspy
Sep 7, 2015 09:09 PM
