ATI Procharger Oil Change
Old Feb 24, 2007 | 11:31 AM
bigslim350Z's Avatar
bigslim350Z
Default ATI Procharger Oil Change
Anyone out there with an ATI procharger try changing the oil by themselves? I ran into the problem where one of the intake pipes is too close to the supercharger so that I can't get a wrench on the drain plug and without taking the whole bracket and unit apart I won't be able to drain the oil that way. Also, I tried using the tool that ATI sent me, (glorified syringe with some tubing attached to it) to draw the oil out from the top. Apparently the tube won't go down far enough and get stuck on something so that way doesn't work either. Anyone else have any luck with the 2nd method? Would it help to warm up the supercharger first. Comments anyone?
Old Feb 24, 2007 | 11:34 AM
bb1314's Avatar
bb1314
da Terminator!
Are you David Stanley?
Old Feb 24, 2007 | 11:38 AM
bigslim350Z
yup, do i know you?
Old Feb 24, 2007 | 11:40 AM
bb1314's Avatar
bb1314
da Terminator!
yup, do i know you?
lol... I was like 9PSI ATI Procharger in MD.... sounds familiar. Yes you do know me. This is Ethan your facebook buddy!
Old Feb 24, 2007 | 12:22 PM
bigslim350Z
ah, nice to meet you on here. passing on info, Capitol Raceway next sunday, March 4th. bring the Z! (and you might need to bring a helmet if you plan on running faster than 14.00) (if you are stock, might not need a helmet, they tend to run 14.10-14.50)
Old Feb 26, 2007 | 07:58 AM
Demonteverde's Avatar
Demonteverde
There is a guy on 350zfrenzy.com by the name of Dr. Bonz (i think, has a beautiful brickyard/purple Z) who documents with pictures different methods of changing the procharger's oil.
Old Feb 26, 2007 | 08:04 AM
Jay'Z's Avatar
Jay'Z
Bro I have your solution!!!!!!!!! Please listen carefully!!!
1. Take your ATI syringe and get your scissors.
2. Take your scissors and cut the syring hose end in a sharp angle.
3. Put some oil on the end or outside the syringe to slip down into the supercharger easier.
4. Slip it in like having sex and push really hard and down.. You are now a glorified oil changing expert!!
Old Feb 26, 2007 | 12:15 PM
bigslim350Z
thanks, will give it a try.
Old Feb 26, 2007 | 03:47 PM
bb1314's Avatar
bb1314
da Terminator!
Classic....
Old Feb 26, 2007 | 03:53 PM
350Z_LEE's Avatar
350Z_LEE
I am about to change mine too for the first time. Unfortunately i don't have this uber sex syringe yall speak of, so i will have to improvise. Or just take the mother apart!
Old Jun 16, 2007 | 07:47 AM
delaharsha's Avatar
delaharsha
I took the front belt off and you can get to the bolt real easy.
Old Jun 16, 2007 | 08:13 AM
350Z_LEE's Avatar
350Z_LEE
I use a loong extension and a wobble socket, and get underneath the car and can get to it very easy. I can change the oil in 10 min now. My cousin showed me that trick.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
