I Can Thank Turbonetics For This!!!
Old Feb 27, 2007 | 09:58 AM
Enron Exec's Avatar
Enron Exec
Originally Posted by sentry65
some people with TT's have actually destroyed their actual turbos where the turbine wheels were all chewed up. At least the TN kit places the turbo up and out of the way and is further away from all the force blowing up in the engine
Still, pieces of the internals can go into the exhaust and into the turbine wheel.
Old Feb 27, 2007 | 10:31 AM
sentry65's Avatar
sentry65
the burninator
very true
Old Feb 27, 2007 | 11:26 AM
Ten to Four Z's Avatar
Ten to Four Z
1. Yes I have that new pipe
2. SSV & 3in Exhaust
3. Mid to high tens pretty rich
Originally Posted by MRC Motorsports
#1)Did you have the Overboost pipe kit? (was it a newer kit?)
#2) did you add mods that increase boost pressure and reduce back pressure such as exhaust, plenum?
#3) What was you A/F like on the kit?
I have noticed the spring in WG in the TN kit does spike a bit, we usually replace them with the 5psi spring to prevent spiking..otherwise you see 9-11psi spikes alot..Even with the Overboost pipe.
Old Feb 27, 2007 | 11:32 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Did a vaccum line come off, or just pure and simple overboost. What boost controller are you using..if any.
Old Feb 27, 2007 | 11:35 AM
Casuale17's Avatar
Casuale17
Yikes! That is running dangerously lean and would be prone to knock. You should be down around 12.5
Edit: Never mind my comment. I misread that and thought you said teens.
Old Feb 27, 2007 | 11:36 AM
Ten to Four Z
Default New Motor
My new motor will have:
wiesco pistons
eagle rods
hks head gaskets
arp hardware
jwt C2 cams
jwt springs
Utec - map switch - boosted control - map sensor
koyo radiator
oil cooler
cjm fuel return
650cc injectors
There is more stuff I just can think of any right now.
By the way Japtrix Is doing all the work.
Old Feb 27, 2007 | 11:38 AM
Eazzy's Avatar
Eazzy
I think the title of this Post should be more like " I can thank a malfunction on my Turboed Motor for this" before pointing a finger at TN----Just my 2 cents
Ten to Four Z
Nope, good old simple overboost. No boost controller.
Old Feb 27, 2007 | 11:39 AM
priscilla ls1's Avatar
priscilla ls1
wiesco pistons
eagle rods
hks head gaskets
arp hardware
jwt C2 cams
jwt springs
koyo radiator
oil cooler
cjm fuel return
650cc injectors
That was fast. I like your piston choice.
Old Feb 27, 2007 | 11:42 AM
Ten to Four Z
What can I say I want my car back. Now I need a bigger turbo with a higher CFM any suggestions?
Old Feb 27, 2007 | 11:45 AM
priscilla ls1
So whats wrong with your turbo did you do an inspection? Any shaft play?
Old Feb 27, 2007 | 11:48 AM
clemlover15's Avatar
clemlover15
whats wrong with a little shaft play now and then..lol
Old Feb 27, 2007 | 11:49 AM
priscilla ls1
I walked right into that one.
Old Feb 27, 2007 | 11:50 AM
Ten to Four Z
Sorry, my turbo is fine but now with the built motor id also like more power!
Old Feb 27, 2007 | 11:53 AM
priscilla ls1
Ohh. Do you want to keep the kit and stay single, and just get a bigger turbo or sell the kit and go twins?
Old Feb 27, 2007 | 12:01 PM
MIAPLAYA's Avatar
MIAPLAYA
So what was the peak boost recorded?
Old Feb 27, 2007 | 12:14 PM
Ten to Four Z
My eyes weren't glue to my gauge, the only number I could remeber was about 12 psi, but it must of been higher.
  #38
MIAPLAYA's Avatar
MIAPLAYA
No peak recall?
Old Feb 27, 2007 | 12:15 PM
  #39
Ten to Four Z
I do want to keep the single kit and get a bigger turbo.
Old Feb 27, 2007 | 12:16 PM
  #40
Ten to Four Z
Nope
