I Can Thank Turbonetics For This!!!
Old Feb 27, 2007 | 12:18 PM
  #41
Sean's Avatar
Sean
still haven't said who tuned it
Old Feb 27, 2007 | 12:20 PM
  #42
Ten to Four Z's Avatar
Ten to Four Z
TN ReFlash
Old Feb 27, 2007 | 12:23 PM
  #43
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Ten to Four Z
Nope
How long was the car running with the kit before this happened?
Old Feb 27, 2007 | 12:33 PM
  #44
Ten to Four Z
Like two days
Old Feb 27, 2007 | 12:34 PM
  #45
Ten to Four Z
It was boosting about 9.5 the days before it overboosted bad I figured 9.5 was because of my exhaust, then a cold night came around and POP went the motor.
Old Feb 27, 2007 | 12:38 PM
  #46
Motormouth's Avatar
Motormouth
I thought stock kit level (and thus reflash) was for 8.5 or something, no?
I guess adding mods and not having it tuned for them is not a good idea.
Old Feb 28, 2007 | 04:27 PM
  #47
DaveFunction2ND's Avatar
DaveFunction2ND
Are you six speed or auto BTW?
Old Feb 28, 2007 | 06:17 PM
  #48
hr2burn's Avatar
hr2burn
I have a TN and with my AEM Tru boost controller on the lowest settings I will hit around 11lbs. I have to run with my BC off and I still hit around 9.5. Makes me NERVOUS!!! I don't have any other mods that affect intake/exhaust or back pressure. It seems silly to me that I should need to lower the 9lbs wastegate spring and a B.C. should keep the W.G. closed until preset boost hit and release before you go above preset limit.
Is that so much to ask?!
Old Feb 28, 2007 | 07:23 PM
  #49
Ten to Four Z
Just get the lower psi spring! Be carefull until you get your boost under control.
I'm going to use the Utec to control mine now.
BTW I have a six speed.
Old Feb 28, 2007 | 07:34 PM
  #50
redman333's Avatar
redman333
You might wat to get rid of the ssv, I was overboosting alot with mine and then I sold it and put on my stock intake with no spacer and I haven't had an issue with overboosting at all, it runs great. I'm using the utec to control boost.
Old Feb 28, 2007 | 07:56 PM
  #51
IIQuickSilverII's Avatar
IIQuickSilverII
no overboosting issues...i run at 8.8 psi...when it got really cold i went as high as 9.2 psi but my a:f stayed under 11.5 so i just drove a lil easy but that was still ok a:f on the safety side....currently using the JIC 3" Ti exhaust non resonated and UTEC...no EBC, just overboost relocation pipe
Old Feb 28, 2007 | 08:20 PM
  #52
widebody350's Avatar
widebody350
kind of a newb question but...A plenum spacer is not recommended with the TN kit?
Old Feb 28, 2007 | 10:40 PM
  #53
MIAPLAYA's Avatar
MIAPLAYA
A boost controller can not make a wastegate open lower then the tension of the spring in the wastegate. You should switch to a 5 PSI or 7 PSI spring if you are going to run a boost controller.
Old Feb 28, 2007 | 10:41 PM
  #54
MIAPLAYA's Avatar
MIAPLAYA
+1 No overboost here either. 8-8.5 PSI since day 1 with NO overboost pipes installed either.
  #55
MIAPLAYA's Avatar
MIAPLAYA
I am running the Motordyne 5/16" plenum spacer for over a year now with no issues
Old Mar 1, 2007 | 01:57 AM
  #56
Audible Mayhem's Avatar
Audible Mayhem
My350z
this is why i hate the reflash, you need an engine management that is boost dependant unless you have wastegates that will not let you overboost or boost higher at all even when its cold outside, and thats not happening....
Old Mar 1, 2007 | 04:51 AM
  #57
IIQuickSilverII
i agree it has its limitations, which is why i like the tuner version of this kit better, and by this i am not going to just say that you must run a UTec(you figure out which one you want)
I love the TN kit, looks HOT!
Old Mar 1, 2007 | 04:57 AM
  #58
IIQuickSilverII
+1 I also got the spacer no issues
Old Mar 1, 2007 | 05:24 AM
  #59
TheOtherRob's Avatar
TheOtherRob
Which z is yours that is at Japtrix? I was there the other day for a dyno day with some friends. Saw a white and blue there getting things fixed.
Old Mar 1, 2007 | 07:03 AM
  #60
Ten to Four Z
The white one with the Work XD9's Bronze.
dynamic6er
Jul 22, 2005 07:31 PM
MIAPLAYA
Jul 8, 2005 05:52 AM
Sharif@Forged
Jul 7, 2005 05:38 AM
MIAPLAYA
May 9, 2005 07:51 AM
