APS External Wastegates are in!
Old Mar 3, 2007 | 06:23 PM
Nealoc187's Avatar
Nealoc187
There is another shop that is soon going to be involved in making an external wastegate setup for the APS TT that I know of but they don't want it posted about yet.
Old Mar 3, 2007 | 06:38 PM
Nismo350ZRT's Avatar
Nismo350ZRT
Originally Posted by tig488
you wouldnt need new housings or downpipes, all you have to do is get the puck welded into the shut position. all you would need is a wastegate outlet welded onto the manifold.
For a "complete" kit you would. That's the whole point of a kit. You just bolt everything up. No fabbing, no welding, just a set of tools would be required. Welding flanges onto the manifolds was discussed before in another thread and was deemed a bad idea. The problem had to do with the durability of the welds.
Old Mar 3, 2007 | 06:56 PM
tig488's Avatar
tig488
nothing wrong with welding cast metal, if the welder knows what hes doing. the pics and info on the tt 06 z06 that i posted had the wastegates welded directly to the cast turbine housings. it looked so good, you would have thought it came that way. not an issue. but maybe somebody will release something soon.
Old Mar 6, 2007 | 01:11 PM
mchapman's Avatar
mchapman
Originally Posted by George@GTM
To be honest I am not sure at this point if we are going to pursue the APS TT ewg relocation kit. It would be very expensive ( new manifolds ) and probally not worth it. I myself am going to be switching to the APS Extreme kit.
Sorry if anyone has been let down by this info, but I have a feeling a EWG kit is in the works by someone else
-George
GT Motorsports
George,
Alot of the newer APS TT kits share the same exhaust manifold as the APS extreme except where the external wastegate pipe would bolt up to the manifold its got a block off plate bolted in. So for those users who have these newer kits they would not need new manifolds, they just need to remove the block off plate and bolt up a flange and piping for the external wastegate to the exisiting holes, weld shut the internal wastgate and either plumb the dump into the exhaust or leave it open.
Old Mar 6, 2007 | 04:00 PM
Nismo350ZRT
Originally Posted by mchapman
George,
Hmm..so other than the different manifolds, is the rest of the standard APS TT kit the same as the older kits? It would really suck if the piping had changed. Do you know if the Extreme manifolds can be used with the older standard kits. I'd like someone to give 100% confirmation on this. I really don't feel like switching to the Extreme since I don't have any desire for 700-800whp. I just want 600whp with solid boost control on the standard kit.
apex locator
Jul 23, 2021 02:27 AM
bcoffee20
Nov 19, 2015 06:39 PM
Tochigi_236
Sep 27, 2015 03:40 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
