Installing a Turbonetics ST kit
Old Mar 2, 2007 | 07:48 AM
boostintt's Avatar
boostintt
Default Installing a Turbonetics ST kit
just got a used tn st kit. it came with the overboost pipe, i got rc 440cc injectors and emanage blue, boost controller, boost gauge, oil p.
I need advise on:
1. exhaust size? type? etc...
2. safety measures...
3. wastegate diff spring? diff wastegate all together?
4. safe boost
5. and any other suggestions for installig the kit????
i jus to dont want to overboost and blow my engine.. thats all.
thanks guys for your knowledge and suggestions.
Old Mar 2, 2007 | 07:58 AM
MIAPLAYA's Avatar
MIAPLAYA
What do you have done to the car right now?
Old Mar 2, 2007 | 08:05 AM
boostintt's Avatar
boostintt
ssv plenum. injen intake, stock exhaust, stock internals.
Old Mar 2, 2007 | 09:25 AM
IIQuickSilverII's Avatar
IIQuickSilverII
on your current mods
0. Sale ShltSV and polish your stock plenum http://www.intensepower.com/inmopoinma35.html
plus ad a plenum spacer http://www.intensepower.com/aamspaninpls.html (OPTIONAL but highly recomended)
3", do this one IMO http://www.intensepower.com/jicmagdetyps.html
or http://www.intensepower.com/an1extitiex3.html or the TopSpeed exhaust
And oil pan spacer wouldn't hurt http://www.intensepower.com/aamspoilpans.html
and since you didn't list it
http://www.intensepower.com/aemaifuga.html
and if possible upgrade from emanage blue to utec
http://www.intensepower.com/tuxsutustuen.html
since you got the wastegate relocation pipe and a boost controller you will be fine on overboosting
4. safe boost
Keep it in the stock boost levels 8.5-8.8 NO more than 9psi and ask for a safe street tune and be happy with what you get
drive it like you stole it! and always check your oil levels etc etc
if you got a Z the oil pressure is useless since you already got that in the center dash gauges...id probably add a temperature gauge there...
For your power levels, fuel return is not necessary, so no need for a fuel pressure gauge.
Old Mar 2, 2007 | 10:10 AM
NA&CH's Avatar
NA&CH
^ do you work for IP?? Can't you just refer the exhaust and let the op decide where to buy? Just a thought. You don' see the tuners come in and paste links to their site around Don't take it the wrong way...
Old Mar 2, 2007 | 10:17 AM
MIAPLAYA's Avatar
MIAPLAYA
Do yourself a favor and ditch the SSV. Below is my answers to your list:
1. 2.75-3" will work fine. I like my Apexi WS2
2. Oil pan spacer would help, wideband and boost gauge. Could also add a Spearco WIS kit to ensure there is no detonation
3. Wastgate is fine as is
4. 8-8.5 PSI
5. Get rid of the Emange blue and get a UTEC, EU, or something else...
Old Mar 2, 2007 | 11:35 AM
IIQuickSilverII
the site itself is great to browse and show all the rig parts anyways and no i don't work for IP, but i would refer people there anytime as they have through the years shown excellent customer satisfaction rating
Old Mar 2, 2007 | 02:15 PM
hr2burn's Avatar
hr2burn
If I have issues @ 6k ft with some spiking and need to drop my W.G. spring down to 7lbs, perhaps this is a good idea also at "O-towns" altitude?
Old Mar 2, 2007 | 03:15 PM
boostintt's Avatar
boostintt
installation has begun....
sneak pics:
http://i16.tinypic.com/4bjdqbo.jpg
http://i19.tinypic.com/33bhcib.jpg
http://i17.tinypic.com/2ykdu78.jpg
tial wg http://i16.tinypic.com/357f28w.jpg
http://i15.tinypic.com/2howdgo.jpg
http://i18.tinypic.com/34y379g.jpg
Old Mar 8, 2007 | 01:24 PM
boostintt's Avatar
boostintt
installation is on its way...
Old Mar 8, 2007 | 01:27 PM
05zissan's Avatar
05zissan
i have the same exact tool box and air compressor as you.
Good luck with the installation.
Old Mar 8, 2007 | 01:30 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Sell the Emanage blue and get a Utec
Old Mar 8, 2007 | 01:51 PM
TayTaythatsme04's Avatar
TayTaythatsme04
I had to drop to a 5lbs spring the overboost was so bad
T
Old Mar 8, 2007 | 02:12 PM
boostintt's Avatar
boostintt
im in orlando fl... no elevation here.
Old Mar 8, 2007 | 02:13 PM
boostintt's Avatar
boostintt
got the tool box for $100 and i love my husky a.c. its done its job...
Old Mar 8, 2007 | 02:14 PM
boostintt's Avatar
boostintt
my buddy has being using the emanage blue for a while and has put out great numbers... so for now ima stick with this and mayb later will upgrade... not to mention the fact that i got both 440 injectors AND emanage for less than $200....
Old Mar 8, 2007 | 05:19 PM
MIAPLAYA's Avatar
MIAPLAYA
T
With a UTEC controlling the boost though correct?
Old Mar 8, 2007 | 06:51 PM
boostintt's Avatar
boostintt
can someone help... which one(s) is the ac line im gonna have problems with?
am i gonna have to get the relocating ac line to have ac?
please see pic:
http://i19.tinypic.com/332xhki.jpg
thanks
Old Mar 8, 2007 | 06:57 PM
2slo2bfurious's Avatar
2slo2bfurious
The one closest to the bottom left, you can just see the part of it in the pic.... you can get it to work, but you might burn a hole in it pretty quick unless you wrap the hell out of it....
Old Mar 8, 2007 | 07:11 PM
boostintt's Avatar
boostintt
you mean this one???
http://i17.tinypic.com/490stn9.jpg
tahnks
