Revup Forced Induction Guys......plenum spacer or no spacer???
Old Mar 13, 2007 | 07:31 PM
QuadCam's Avatar
QuadCam
Default Revup Forced Induction Guys......plenum spacer or no spacer???
This is to all the FI Revup cars out there.
Are you running a plenum spacer or larger plenum (crawford, aps, etc) or did you just leave the upper plenum alone?
Old Mar 14, 2007 | 12:33 AM
3.6z's Avatar
3.6z
i wouldn't care that much about it.
Old Mar 14, 2007 | 12:35 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
lol, you wouldnt care too much about it or you wouldnt worry too much about it??
i have spacers here andrew if you want to dyno one, i thought you had one on there already though??
Old Mar 14, 2007 | 06:42 AM
QuadCam's Avatar
QuadCam
Jeremy,
I do have a 5/16" spacer, but I was wondering if anyone ever tested a spacer out on a F/I Revup application.
From what I have heard, a spacer does nothing on an N/A revup motor. I have the spacer from when I was using the MREV2/spacer setup.
I guess we need to set up that intake manifold shootout.
I have a:
1) Revup Plenum
2) MREV2 Plenum
3) 5/16" spacer
I have access to a ported Revup Plenum, too.
What do you have?
stock 287 plenum?
your "shorty" plenum?
skunk2 spacer?
Old Mar 14, 2007 | 08:05 AM
clemlover15's Avatar
clemlover15
that has been done in sportZ mag I can't remember which issue/
I have the 5/16 and MREV in my rev-upTT
Old Mar 14, 2007 | 09:45 AM
QuadCam's Avatar
QuadCam
........not on a forced induction revup! That test was on N/A cars.
Old Mar 14, 2007 | 10:58 AM
clemlover15
very true I wish more people did testing of FI Z's!!
Old Mar 14, 2007 | 01:57 PM
TENGAI's Avatar
TENGAI
i just ordered the MREV2 and the APS tallboy for my '06 revup... NA or FI, you should see some gains.
Old Mar 14, 2007 | 02:06 PM
Mid117's Avatar
Mid117
False.
I did a before/after dyno of an AAM Spacer install on my Rev-up Z. I gained 5whp all across the board.
Old Mar 14, 2007 | 02:14 PM
singh's Avatar
singh
_______________
Originally Posted by Mid117
...I gained 5whp all across the board.
Old Mar 14, 2007 | 02:37 PM
Mid117's Avatar
Mid117
Originally Posted by gsingh350Z
I'd post the graphs, but I don't have a scanner.
Old Mar 14, 2007 | 02:53 PM
QuadCam's Avatar
QuadCam
False.
5HP across the entire graphs sound odd.......I could see gaining 5hp up top on a mod like this, but not all the way across the board.....
You can do back to back dyno runs and pick up gains like that.......I've seen it before.
Old Mar 14, 2007 | 02:56 PM
singh's Avatar
singh
_______________
sarcasm > you
Old Mar 14, 2007 | 09:04 PM
Abishop's Avatar
Abishop
im interested in this too.
Old Mar 15, 2007 | 05:53 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
I don't think a spacer alone on a FI set up will do much of anything on a REVUP lower collector.
But I'd like to see the MREV2/spacer combo tested on a FI REVUP.
Alberto (and others) have tested the 287 lower plenum (with a spacer or crawford upper) on their FI 287 engine and then tested the same set up with a REVUP lower collector.
Apparently the REVUP lower collector loses power everywhere on the curve when on a FI 287 engine.
The result will most likely will hold true on a FI REVUP engine, but it still needs to be tested.
I would have tested this myself but I don't have FI
Old Mar 15, 2007 | 06:03 AM
Alberto's Avatar
Alberto
Cranky FI Owner
+1 Good memory. I figured the Revup would make more power, seemed bigger = more volume & better flow but it KILLED my midrange TQ and never even made up for it in the top end, resulted in a power loss everywhere. I tested it with my TN kit and decided to switch back to the standard lower plenum. I have no idea how guys who do this NA say it helps them. Take it for what its worth.
