New Plans for the Vortech Coupe
Old Mar 20, 2007 | 08:14 PM
NS_350GT's Avatar
NS_350GT
Originally Posted by booger
You can almost bet when they tried to upload your maps from the SS box . They didnt know how to reset the settings and the aux fuel pump will not come on untill the settings are reset .
Tell Jotech to call SplitSecond and they will walk them through it
Jotech did call split second and told them that all the settings are wrong, split second did walk them through adjusting the settings. Jotech also downloaded the software that day. They said they have worked on the SS box before, so who knows what happend. Hopefully it is actually a good box and SGP can fix this problem. Vortech said the settings reset everytime you plug into the box and you have to go back and reset everything.
Vortech said the recalibration for the 440cc injectors for the Vortech FMU is the 12 to 1 kit.
Old Mar 20, 2007 | 09:28 PM
NS_350GT's Avatar
NS_350GT
Ok i just found that AAM has a fuel return sytem basic kit that seems like a great deal. I am now strongly considering this and loosing the FMU. Anyone know the Difficulty of install on something like this?
Old Mar 21, 2007 | 03:21 AM
Barzten1's Avatar
Barzten1
Originally Posted by rocks
400$ for a compression test is outrageous. The tool to do it costs like 25$ at autozone and you can do it yourself in about 20-30 minutes.
Hows everything working out for your Z with the built motor?
Old Mar 21, 2007 | 05:08 AM
booger's Avatar
booger
I sure hope you are wrong on the FMU . The 03-04 kits had a 8 to 1 FMU and after that they went to a 6 to 1 . A 12 to 1 would be wayyyyy to much fuel preasure . Did you mean 2 to 1 ?
Old Mar 21, 2007 | 07:23 AM
NS_350GT's Avatar
NS_350GT
Not sure thats what vortech said may have miss heard, either way i will be going with AAMs fuel return system, 440cc injectors. Anybody know how hard these would be to install?
Old Mar 21, 2007 | 09:10 AM
Gilley's Avatar
Gilley
The CJ Racing fuel return system is highly regarded.
Old Mar 22, 2007 | 06:18 AM
DaveFunction2ND's Avatar
DaveFunction2ND
Take the Vortech FMU out. With the return fuel system and 440's there is no need for it. Also make sure to get a Walboro 255.
Old Mar 22, 2007 | 07:27 AM
NS_350GT's Avatar
NS_350GT
I have a Walbro 255, will then be self installing fuel return kit, 440cc injectors and 3.12 pulley while the ecu is being flashed at AAM then taking it to SGP so they can tune the SS Box.
Old Mar 22, 2007 | 09:40 AM
Gilley's Avatar
Gilley
Why would you want to flash the ECU and then tune the SS box?
Old Mar 22, 2007 | 09:53 AM
sentry65's Avatar
sentry65
the burninator
he was having trouble scaling his injectors with the SS box
I can attest to the car starting and idling LOTS better with the ECU flashed for the larger injectors
Old Mar 22, 2007 | 10:44 AM
Gilley's Avatar
Gilley
Why not skip the flash and ditch the SS box for a UTEC so the fuel and timing can be tuned?
Old Mar 22, 2007 | 11:20 AM
NS_350GT's Avatar
NS_350GT
At this point I would rather have a Fuel return system & still use the ss box if its good and have that tuned. Which im thinking it was good all along.
Old Mar 28, 2007 | 10:53 PM
zzerotwosixty's Avatar
zzerotwosixty
Are you buying the pulley and cog belt from Vortech? I didn't see any 3.12 on their site. Is this 28,30,32 tooth? I'm assuming 34 is original. Thanks in advance. I need more power.
Old Mar 29, 2007 | 04:46 AM
Gilley's Avatar
Gilley
I bought my 3.12 pulley from Vortech. It's a 6 rib pulley. I bought the Gates cog belt from www.motionindustries.com for about $20.
Old Mar 29, 2007 | 07:35 AM
zzerotwosixty
You're not changing the toothed pulley on the back of the supercharger?
Old Mar 29, 2007 | 07:56 AM
Gilley's Avatar
Gilley
No, the pulley you change is the 6 ribed pulley on the front of the jackshaft. And in that case, you need a shorter serpentine belt.
Old Mar 29, 2007 | 08:16 AM
zzerotwosixty
Damn, I already bought two spares. Edit: So the diameter of the pulley is 3.12"?
Old Mar 29, 2007 | 08:31 AM
  #38
zzerotwosixty
I get it now. What size serpentine for the 3.12 pulley? You said you bought another cog belt from Motion. Why? I have two spares of those too. Paid 45$ each.
Old Mar 29, 2007 | 09:08 AM
  #39
jpc350z's Avatar
jpc350z
And if you do what is suggested here be prepared for about an 80 psi fuel pressure level (at idle and non boosted) or make the mod's called out in the Turbonetics install manual on the walbro and also the mode to the swirl jet that Phunk suggests to get the press down to around 50psi. Need this MOD even if you remove the FMU and Aux fuel pump..Hope this helps.
Old Mar 29, 2007 | 10:25 AM
  #40
Gilley's Avatar
Gilley
We really shouldn't be jacking the OP's thread, but you need a 93 inch belt for the 3.12 pulley. You'll need a retune also.
I bought a cog belt because mine broke. I got it from motion industries because they were inexpensive for the same Gates cog belt that comes with the kit. I got two belts for about $35. Superchargersonline.com had them for $39 each plus shipping.
