Pulley fell off!!? or what?
Old Mar 20, 2007 | 10:55 AM
Gilley's Avatar
Gilley
I'm surprised the car will run fine without the AC part on it. You aren't throwing any codes?
Old Mar 20, 2007 | 10:57 AM
sentry65's Avatar
sentry65
the burninator
you don't need the AC to run the car
people can completely remove the AC and run the car
it looks like just the face plate of the pulley came off
Old Mar 20, 2007 | 11:34 AM
Bwicked's Avatar
Bwicked
yap car ran fine w/o out, however..... turns out something else went wrong somewhere... took it to two local shops less then 5 mins away. neither will work on it cuz a) its foreign b) its supercharged
However both looked at it and heard it and believe it's something internal.... one even mentioned it sounded like rod went out ...... having it towed to GRD 2mrw to diagnose what happened..... i guess the track day took its toll?
Old Mar 20, 2007 | 11:36 AM
Sean's Avatar
Sean
yep....at least you can go forged now.
Old Mar 20, 2007 | 11:58 AM
sentry65's Avatar
sentry65
the burninator
a bend rod? keep us updated
i'm not at all suprised given your power levels, but it will be one of the first incidents of a bent rod on a vortech. If that is the case, at least the rod didn't snap and break a hole in the block and you're still able to at least drive the car - something most vortech owners who damaged their engine have been able to do
BTW what octane gas were you running at the track?
I'm paranoid to run anything less than around 96 octane (mix of 101 and 91)
it sucks that water injection was one of your next mods (if I recall)
maybe it could have helped out the engine during those 1/4 mile runs - if the engine does turn out to be damaged
Old Mar 20, 2007 | 12:41 PM
Bwicked's Avatar
Bwicked
93 oct all the time...ill get an update 2mrw, may not be a rod or something bad, but not taking chances this time. is driveable though, but def feels like i've lost alot of power. doesnt respond the same either
Old Mar 20, 2007 | 12:43 PM
sentry65's Avatar
sentry65
the burninator
you might have chipped a ringland on one or more of your pistons - this has happend to almost ALL people with engine damage who were running vortechs. A compression test should tell you
Old Mar 20, 2007 | 12:51 PM
XxKwestxX's Avatar
XxKwestxX
signing up for an update. Very curious to see what the problem is.
Old Mar 20, 2007 | 03:00 PM
MIAPLAYA's Avatar
MIAPLAYA
Hmm thats interesting. Looking forward to the results...
Old Mar 20, 2007 | 03:09 PM
Bwicked's Avatar
Bwicked
lmao at ur sig miaplaya. updates tomorrow
Old Mar 20, 2007 | 03:32 PM
drifter23's Avatar
drifter23
Very interesting problem you have. My Vortech made a clunking and clicking noise too. When I was going WOT on the freeway. And I thought my engine was going to blow up. Towed it to the shop (Z cargarage) and found out that, my cog belt was ripped to shreads and was causing the clunking noise. My noise came from the blower side. And it freaked the shiat out of me. Sounded like my engine was hitting metal to metal. My tuner was puzzled too on how the belt got ripped to shreads. Hope your problem is not a serious one.
Old Mar 20, 2007 | 04:01 PM
Bwicked's Avatar
Bwicked
id love for it to e only that problem! i hope so cross ur fingers! lol
Old Mar 20, 2007 | 04:23 PM
MIAPLAYA's Avatar
MIAPLAYA
Glad I was able to lighten your mood a little. Keep your chin up.
Old Mar 20, 2007 | 08:19 PM
Bwicked's Avatar
Bwicked
Soo another update today while car was being picked up, so far it seems that I have spun a rod bearing.... any ideas on type of work involved with that? labor time? cost more or less?
Old Mar 20, 2007 | 08:30 PM
westpak's Avatar
westpak
SFZCC
Pretty much engine disassembly.
Old Mar 20, 2007 | 08:33 PM
sentry65's Avatar
sentry65
the burninator
my guess is that means the bottom end has to be taken apart and put back together again, but I'm not an engine builder to know for sure
Old Mar 20, 2007 | 08:35 PM
Sean's Avatar
Sean
If you can afford it, have a rebuild with strong parts done. If not, that my guess would be 850 labor alone.
Old Mar 20, 2007 | 08:41 PM
  #38
eckocomplexg's Avatar
eckocomplexg
damn B, I'm sorry to hear about this..... let me know what happens... hopefully running the engine on no tune for as long as you did didn't take its toll
  #39
sentry65's Avatar
sentry65
the burninator
you might not actually have to have the engine removed. They might be able to get to it through the oil pan - but I dunno
Old Mar 20, 2007 | 08:57 PM
  #40
Bwicked's Avatar
Bwicked
if i got for the built motor, anyone know where i can get the parts at? how much should rods and pistons cost? (performance) looking to stay in the 550-600 rwhp range if i go built
