First test with the Vortech cog system
Old Apr 6, 2007 | 06:42 PM
booger's Avatar
booger
Originally Posted by sentry65
looks good booger! We'll all be curious to see what the final numbers end up at.
This kinda makes me more inclined to stick with the normal blower since I'd like to be able to rev to around 7000-7500 rpms with a built block - or at least have the headroom to do so. The T-trim sounds like it'd make 30 psi at 7500 rpms which is uh well a lot
The Haltech sounds like a great product, but seems like the first versions of these sorta things always have a million bugs
the Fcon has been around and been worked out for awhile now
the biggest reason for stopping where I did , was the SS box not being able to control above 16psi . Plus boost comes on so fast after 5500rpm.
Old Apr 6, 2007 | 06:44 PM
booger's Avatar
booger
Originally Posted by THE TECH
Is that rod on the jackshaft there to help prevent the premature wear on the jackshaft?
Its there to help keep the mounting plate from flexing . So is the outter plate you see
Old Apr 6, 2007 | 07:02 PM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by booger
thanks Mia...I'll look into it . But if its only in MAF instead of MAP.....dont know .
It runs off of MAP...
Originally Posted by Haltech
Tuning via TPS with Manifold pressure correction
It can do either honestly but it does MAP...
Old Apr 6, 2007 | 07:04 PM
MIAPLAYA's Avatar
MIAPLAYA
Haltech has been making ECUs for years now for Nissans, Mazdas, etc. The RX-7 guys are very happy with them and some Spec V guys have started using them as well. Like I said before Danzio out here in Socal got it running the cam timing. Link to that: http://danzioperformance.com/customer_cars_16.asp
Old Apr 6, 2007 | 07:20 PM
Quamen's Avatar
Quamen
Looking good booger!
Old Apr 6, 2007 | 08:13 PM
THE TECH's Avatar
THE TECH
So Vortech did this prototype and never did anything else with it? Maybe you should duplicate it Booger and sell it here.
Old Apr 7, 2007 | 05:58 AM
booger's Avatar
booger
The one thing I see with a stand alone is that they will all have the same problem as the Hydra is having . Controling the AT5 tranny . And until all of them work through that , guys with the AT5 are left out of using the stand alone EMS .
Right now.....and after sitting and thinking for a day . I have more important thnigs to get paid off right now . So it may have to wait longer than I really want it to anyway . So maybe some one will work through controlling the tranny in the mean time .
Old Apr 7, 2007 | 06:01 AM
booger's Avatar
booger
THANKS everyone !
I was very surprised the boost built up so fast . The T-trim really gets going after 5500rpm
Old Apr 7, 2007 | 05:37 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Good work Booger!
Post pics!
Old Apr 7, 2007 | 06:14 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
Nice Booger!!
i never thought i would use that phrase in my life, seriously though, just get a utec and you will be fine with your EMU problems.
are you on a built block (i hope)
Old Apr 7, 2007 | 07:07 PM
booger's Avatar
booger
Originally Posted by Audible Mayhem
Nice Booger!!
LOL
Built block...wouldnt even think about it with out .
+1
Good work Booger!
Post pics!
In the first post Hydrazine
Old Apr 7, 2007 | 07:11 PM
Quamen's Avatar
Quamen
Is the T-trim the same style impeller as the standard trim headunit with slighlty different dimensions? I noticed that their impeller design on the standard trim could be improved slightly for some increased airflow something along the lines of 10-15% more CFM. Just wondering if the same goes for the T-trim?
Old Apr 7, 2007 | 07:21 PM
booger's Avatar
booger
I had the impression that the T-trim had about the same impeller but with closer tolerances .
I think if you saw a standard blower with a cog set up . You would see it make more boost than it does with a serp belt . I believe Vortechs web site say the the standard blower can make 20psi and the T-trim 24 or 26psi...not exactly sure on both
Old Apr 7, 2007 | 07:23 PM
booger's Avatar
booger
remember guys....I have a extra T-trim blower for sale.....I'll throw in the bracket and pulleys also .
Old Apr 7, 2007 | 07:44 PM
Audible Mayhem
My350z
nice man, what kinda numbers did all that high boost put down with your blower...??
Old Apr 7, 2007 | 08:49 PM
KPierson's Avatar
KPierson
He reported gains of 20+ WHP across the band just by messing with the cam timing.
It would be very interesting to see some graphs to back up that report. From my recent research I don't think any tweaking of VVT will add any HP above 4000RPM. At that point the timing is as aggresive as it will go, so I'm not sure how you would squeeze out more power.
I would expect to see a 20whp gain from 2500-4000RPM though with proper tuning.
Old Apr 7, 2007 | 08:54 PM
Audible Mayhem
My350z
hey kevin, hit me up next time you are on aim, i am thinking about unpluging the VCT or actually feeding it full power so it stays open.
let me know your research so i can figure out some stuff...
Old Apr 7, 2007 | 09:31 PM
  #38
KPierson's Avatar
KPierson
From what I have seen you are better off leaving it alone.
The valve timing at idle is roughly 2 degrees from the crank. If you supply constant power it will go all the way to 40 degrees or so, and the car won't idle very well (mine actually stalls). You will also lose top end power.
If you disconnect it all together I believe you will drop midrange torque, but will keep your power up top. Once I get my new spark plugs installed I'll be back on the dyno to confirm this. My last test didn't do what it was supposed to do.
Sorry for OTing!
Old Apr 7, 2007 | 09:37 PM
  #39
Audible Mayhem
My350z
hellyeah!! how sure are you on this kevin, i will unplg them right now!!
heheh
let me know
Old Apr 7, 2007 | 09:38 PM
  #40
MIAPLAYA's Avatar
MIAPLAYA
I'll see about getting some graphs from Danzio on Monday.
