Turbonetics Problem
Old Apr 14, 2007 | 11:51 AM
blazersman's Avatar
blazersman
Default Turbonetics Problem
First off, I want to say thanks to Function Tuned for a great install and tune for my 5at Z. I plan to make a more discriptive thread about my good experience with them.
I was on my way home last night (after winning a cash prise bracket race!!!) and lost power on the interstate right next to the exit ramp I was getting off of (thank god). I sat there brainstorming what the problem could have been for a second, then my girlfriend looks at me and says "it felt like you just ran out of gas." I was thinking "wow, that would be a problem too easy to fix." Sure enough, after getting back to the car and getting gas in it, it started right up. The check engine light was on, so I took it to Advanced to check it's codes. It threw the gas gauge sensor code! It seems that this might be a sort of common problem with turbonetics kits for some reason. Even after I filled the car up shortly thereafter, the gauge didn't show a full tank. Does anyone know why? Anyone else had this problem? Any fixes?
Any help would be appreciated!
Old Apr 14, 2007 | 12:20 PM
MIAPLAYA's Avatar
MIAPLAYA
Um no. This has zero to do with the Turbonetics or any turbo kit for that matter. It sounds to me like your fuel level sensor has either gone bad or its connection has come off. It might have been a faulty connection during install but its not caused by this or any other turbo kit. The only issue I have heard of is that when below 1/5 of a tank of gas when boosting and taking corners quickly the car may go slighlty lean due to fuel starvation but has nothing to do again with the fuel level sensor not reporting the correct amount of fuel in the tank.
Old Apr 14, 2007 | 12:22 PM
VIZAGE's Avatar
VIZAGE
I've always wondered after fooling with the fuel pump during upgrades and putting it back, does it throw off the float a little? I notice on my car that when I'm at about 1/4 of a tank it shows on the display gauge that it can still get near 200 more miles on what's left in the tank. I just keep it above 1/4 of a tank full anyways.
Cause my daily driver Camaro been doing this for years so it's normal to me.
Old Apr 14, 2007 | 01:16 PM
Sisith's Avatar
Sisith
If you are talking about the DTE gauge it is going to read higher with bigger injectors since you have them on shorter pulse widths than the stock injectors...it still thinks the stockers are in there just spitting out less gas
Old Apr 14, 2007 | 01:22 PM
IIQuickSilverII's Avatar
IIQuickSilverII
you may need to check your installation of the walbro Fp...bad gauges could also be a problem... does it overflow when you put gas?
Old Apr 14, 2007 | 01:23 PM
IIQuickSilverII
+1...bottom line you dont wanna stay low on fuel with an aftermarket FI car
Old Apr 14, 2007 | 01:59 PM
VIZAGE's Avatar
VIZAGE
Thanks for the info. I did not know that at all.
Old Apr 16, 2007 | 09:06 AM
DaveFunction2ND's Avatar
DaveFunction2ND
Argggghhhh.....looks like the dreaded stock siphon line has struck again! Sorry about this man. I take extra caution when installing the fuel pump becasue the stock siphon line is notorious for trapping the fuel level sensor and causing bad readings. This is what happened. Its a pretty simple fix so I can walk you through it over the phone. Just give me a shout.
Otherwise glad to hear you're happy with the install!
Old Apr 16, 2007 | 09:09 AM
taurran's Avatar
taurran
Yes... the turbo worked its way into your fuel tank and broke it.
Old Apr 16, 2007 | 10:57 AM
IIQuickSilverII
Old Apr 16, 2007 | 11:40 AM
DaveFunction2ND
I think he was refering to the fuel slosh at 1/4 tank low level issue. Fortunetly we did not modify his fuel pump assembly other then for the pump so he still maintains full factory siphon fill capability.
Old Apr 16, 2007 | 12:52 PM
hr2burn's Avatar
hr2burn
Okay, since we are on the subject...
I have the less than 1/4 "slosh problem" no biggie keep gas in her.
BUT when I have a 1/4 tank within a few miles it will works it's way down sooo low the gas light will come on, then a few more miles....TA-DA! I get my 1/4 tank back!!!!
HELP! any ideas?
Thanks, Sean
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
