ATTN: PE TT OWNERS post your #'s
Old Apr 15, 2007 | 08:58 PM
gcoupeturbo's Avatar
gcoupeturbo
Default ATTN: PE TT OWNERS post your #'s
Please post your dyno's numbers @ the boost (PSI) set
Im trying to get an idea on what numbers other have made.
Im kinda disappointed in my numbers.. but kinda want to know what others have made.. thanks
My #'s
At 15 PSI
Max Power : 493HP between 6000-6500 RPM
Max Torque : 495TQ @ 4500 RPM
Correction Factor : UNCORRECTED, Smoothing : 5
Run Type : RO
Run Conditions: 61.23 F, 29.60 in-Hg Humidity: 8% UNCORRECTED: 1.0
I might have to get this verified because AAM tuned it in a low boost setting and a high boost setting.. i'm not sure which this dyno was based on... will update and post tomorrow
Old Apr 15, 2007 | 10:57 PM
350z-900whp's Avatar
350z-900whp
my Pe-TT Z will be finished by the end of this month hopefully. I’m expecting anything a 480+whp. We well see what will happen
Old Apr 16, 2007 | 01:23 PM
gcoupeturbo
are you running on a built motor? or stock?
Old Apr 16, 2007 | 01:25 PM
350z-900whp
with a built short block
Old Apr 16, 2007 | 01:31 PM
gcoupeturbo
sweet.. i'm using my turbonetics intercooler and it was on pump gas.. hopefully i will have that upgraded and go beyond 15psi.. only if its a conservatively reliable tune...
Old Apr 16, 2007 | 01:46 PM
350z-900whp
my modes are
Pe-TT
RC 650cc injectors , fuel line custom, walbro fuel pump in tank , automotive 1000 fuel pump
short block : CP pistons 9:1 , GTM rods , sleeved liner, HKS gaskit , arp L19 head stud, arp stud , Pe oil pan , L&R ss pulley set , Bypass coolant, oil catch tank, NKG one step colder
HKS blow valve SSVQ , HKS boost controller EVC , TEC3 stand alone
koyo radiator 2raw , sacoma hose kit
HKS exhaust Ti, custom Test pipe
JIC coilover, hotches kit swaybar
RPS flywheel , ACT clutch
A/F ratio gauge , 25psi boost, Exh Temp
Volk 18inch rims F 9.5 R 10
etc....
Old Apr 16, 2007 | 01:48 PM
350z-900whp
so your using a Pe-tt with turbonetics intercooler .
Old Apr 16, 2007 | 01:51 PM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
I dynoed a high of 470 on a dynojet, but dyno 410 to 420 on Sharif's dyno. My highest trap is 119mph my fastest trap 11.9. Stock block @ 11ish Psi.
Old Apr 16, 2007 | 02:15 PM
rocks's Avatar
rocks
Little bitty turbos on that kit arent going to get you a ton of power. 500hp is nothing to laugh at, i dont see why your dissapointed.
Old Apr 16, 2007 | 02:32 PM
gcoupeturbo
i wouldn't say im disappointed.. i just know that on a dyno jet, the numbers are much lower on the dynodynamics or the dyno mustang.
just wondering, which is the best dyno to use?
Old Apr 16, 2007 | 03:26 PM
gcoupeturbo
Old Apr 16, 2007 | 03:46 PM
eagletanggreen
Got Track!!!!!
Take it to the track and see what kinda trap speed you are getting. IMO I believe thats the real test as far as what Hp your really putting down. I always thought my car was putting down crazy Hp, but when I went to the track I was trapping 116 on hot days and 119 on a cold day. Those mph are 400 to 420 rwhp. So with 495 rwhp you should be trapping in the high 120's. All this HP going around doesn't mean crap unless you can put it down. There are only a few guys on this forum that I know that can hold his own driving 500hp cars (not driving on the highway going straight in 5 and then punching it). Like I said if you really want to see what your car is really putting down, take it to the track. You will be very surprise.
Good numbers, you should be happy with those.
Old Apr 16, 2007 | 03:52 PM
gcoupeturbo
i can't wait to do so.
Out of curiousity, which dyno is most accurate, or more reliable to post?
Old Apr 16, 2007 | 05:25 PM
eagletanggreen
Got Track!!!!!
I would use Dyno dynamics, or a mustang dyno with zero correction, but most important keep using the same dyno.
Old Apr 16, 2007 | 05:32 PM
rocks's Avatar
rocks
If you want a good idea of the power take it too 3 seprate shops and have it dynoed. That should give you a good idea of the power diffrence between dynos.
Old Apr 16, 2007 | 09:12 PM
priscilla ls1's Avatar
priscilla ls1
Dyno Dynamics for sure.
Here is what I got and way more to come.
PETT built 3.7 8.8
438hp 485Tq @11psi
Old Apr 17, 2007 | 10:20 AM
Chebosto's Avatar
Chebosto
gcoupeturbo:
what engine mgmt are you using for 15psi?
Old Apr 17, 2007 | 10:31 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Fcon
Old Apr 17, 2007 | 07:17 PM
gcoupeturbo
yup.. the expensive, money snatching, wallet burning hks fcon... i haven't gotten my car back, but im sure its worth every penny
Old May 21, 2007 | 03:08 PM
gcoupeturbo
oh yea. i got the car back... im scared to drive it... soooooo fast
