Spark Plugs: Platinum or Iridium for F/I ??
Old Apr 20, 2007 | 10:16 PM
Triple8Sol's Avatar
Triple8Sol
Default Spark Plugs: Platinum or Iridium for F/I ??
I installed NGK Iridium (LFR6AIX-11) 1-step colder plugs with the stock gap when I installed the Stillen stage 4 s/c. Have been running them for about 7 months and 9000 miles. Pulled them today to check them out because I had some pinging awhile back (now fixed). Looking at them, I think it would be a good idea to change them.
Stillen's install instructions recommend NGK Platinum (PLFR6A-11) 1-step colder plugs. I know that alot of guys with various FI setups are running iridiums though. I'm just trying to figure out what to get this time around.
Does it really make a difference which of these 2 I use? Could one possibly be any better for my setup than the other? If so, why? Thanks in advance
Old Apr 21, 2007 | 06:29 AM
QuadCam's Avatar
QuadCam
go for the NGK Copper plugs or the Iridiums......stay away from platinum for performance. Platinum, by nature, is not a good conductor. It is hard, which lends itself to longevity.
Old Apr 21, 2007 | 09:45 AM
eltness350's Avatar
eltness350
The Untouchable
iridium and close the gap more then stock...supercharges tend to "blow out" the spark
Old Apr 21, 2007 | 07:31 PM
Triple8Sol's Avatar
Triple8Sol
From what I understand, you have to change out coppers much more often, right?
I thought iridiums were too sensitive or fragile to gap?
Old Apr 21, 2007 | 07:38 PM
rocks's Avatar
rocks
Platinum is very bad for turbocharged cars. Look it up, putting Platinum plugs in your engine can blow it up.
Old Apr 21, 2007 | 07:45 PM
Triple8Sol's Avatar
Triple8Sol
Why does Stillen recommend Plats then?
Old Apr 21, 2007 | 10:17 PM
rocks's Avatar
rocks
Platinum stores heat and will cause detonation in turbocharged engines. I actually made this mistake a few years ago and almost blew up an engine i had. The spark plugs were pitted.
Old Apr 21, 2007 | 11:20 PM
Devil Z's Avatar
Devil Z
He Doesn't Have A Turbocharged Car Lol.
Old Apr 22, 2007 | 01:39 AM
Triple8Sol's Avatar
Triple8Sol
That's correct. It's a supercharger. Does that completely nullify what you're saying then?
Old Apr 23, 2007 | 04:59 AM
jpc350z's Avatar
jpc350z
I have had platinums in for 11,000 miles and recently examined them and they were fine..
Old Apr 23, 2007 | 05:02 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Iridiums
Old Apr 23, 2007 | 08:11 AM
rocks's Avatar
rocks
Supercharger and turbocharger are both forced induction. You are better off with iridiums or coppers. I actually prefer copper plugs. Copper is cheaper, like 1.50$ a plug. Even if you soak them with gas they will still spark unlike iridium. makes it nice to tune with to get a car running right at idle if you foul the plugs at first.
Old Apr 23, 2007 | 10:44 AM
Enron Exec's Avatar
Enron Exec
Posts #2 and #3 scare me....
That is almost sig worthy...
Old Apr 23, 2007 | 10:48 AM
JCat's Avatar
JCat
Platinum is not recommended with Nitrous. Iridiums are.
Old Apr 23, 2007 | 10:56 AM
jpc350z's Avatar
jpc350z
Your post is equally scary... Care to elaborate??
Old Apr 23, 2007 | 12:27 PM
eltness350's Avatar
eltness350
The Untouchable
my buddy is a tech for nissan and he said with iridiums 1 step colder u should close the gap a bit more...i check mine every couple of months but this works the best for me...and y r our comments scary cupcake??
Old May 1, 2007 | 12:20 AM
Triple8Sol's Avatar
Triple8Sol
Any more opinions? Hopefully backed up with some theory or actual facts?
Old May 1, 2007 | 12:52 AM
Cube's Avatar
Cube
Yeah I have an opinion. I've heard that using copper is recommended because you want the spark plug to be a failing point. Copper is obviously the "weakest" of the 3 materials and will melt or fail before the other two.
In the event something were to happen that would cause cylinder damage, either to pistons, rods, valves, you name it, you'd want the spark plug to fail which would stop the combustion, or detonation process to prevent further damage.
An iridium will take the abuse and keep on sparking, a platinum even more so, but the copper would be the first to fail.
Please let me know if this makes sense, I may have worded it weird. Oh and I am speaking about FI application where more extreme detonations are expected (if they occur, when compared to "less extreme" detonations going NA).
Old May 1, 2007 | 01:38 AM
VicPham's Avatar
VicPham
Lifetime Member
0o0o0o.....im subscribing to this. Im installing my nitrous really soon, so I would definately like to know whether to use copper or iridium 1 step colder plugs.
Old May 1, 2007 | 01:59 AM
silver nismo's Avatar
silver nismo
Denson 1 step colder r realy good and here is 2 step colder as well..
