Weight of Oil when Going Twin Turbo?
Hey guys, i searched and came up with nothing.
I also read the sticky, i didn't get a clear answer with everyone posting up different weights? Why?
I run Amsoil 5w30 in my car now. When i go to the APS TT kit, what oil weight should i run? The car will be driven in temps below 32F (sometimes in winter) and mostly on nice days 40F+, at the drag strip, and maybe road course ( twice a year ) if i grow some *****. So what weight do you guys use and why?
Also, im getting the APS kit wich comes with a bigger oil pan, which holds up to 6.25 total quarts now, do you guys full all 6.25 quarts or just 6 qts?
Originally Posted by Abishop
Why did u choose that?
that was the recommendation from my tuner/installer... ran it last winter.. no problems.. granted i didn't drive the car when it snowed.. but couple of times it was below freezing.. the car was fine
I wouldn't put that much oil in your car if your running the APS TT...With the APS oil pan on the TT you only need 5 1/2 quarts and that includes putting a new filter on. Remember your oil only needs to go to the LOW level on your dipstick with the APS TT...This had been discussed and agreed on many times in the past. Mobil 1 Syn...10w40 for me and no problems
Why did you choose that?
Originally Posted by IslandZavage
i was gonna go 5W30 Royal Purple..
what oil do you use now? i been using it N/A...thought of using it TT also...
Originally Posted by failsafe306
If you live in a climate that has drastic seasons, I'd run a heavier oil in the summer, and a lighter oil in the winter.
10w/40 is probably a good happy medium though.
ISnt that backwards?
Can anyother APS TT guys confirm this?
