Vortech Question
Old May 7, 2007 | 07:16 AM
anubyss's Avatar
anubyss
Default Vortech Question
I recently had a tuning session for my Vortech with 3.12 pulleys and 440cc injectors with Utec. I have the Walbro pump with TN fuel regulator mod. I seem to be running out of fuel above 6400rpm at 9psi. Everything else seems to be fine. The question is, I still can't adjust the fuel pressure even with the mod (up or down). The fuel pressure remains pretty constant at ~56 psi even in boost. Is there a way of just removing or bypassing the stock regulator? I can always upgrade the injectors and keep everything as is I guess. Thanks for everything Julian and sorry for having to make you wrench a bit .
Old May 7, 2007 | 07:33 AM
MUZZY's Avatar
MUZZY
yes.. I hade the same problem. Running real lean in high RPM. get a AAM basic fuel return system. Gets rid of the stock regulator and you will have all the fuel you want.
Old May 7, 2007 | 07:49 AM
anubyss's Avatar
anubyss
Damn I was really trying to avoid getting a return system lol. Another $550 drain in the wallet plus whatever the bigger injectors are going to cost me. Thanks for the input MUZZY.
Old May 7, 2007 | 09:44 AM
NS_350GT's Avatar
NS_350GT
Heres what came in my kit. Does it replace the stock regulator? I still need to go over the directions again.
Old May 7, 2007 | 09:49 AM
anubyss's Avatar
anubyss
I am assuming it comes with a rising rate fuel pressure regulator which would replace the stock one. I am just unsure how the connections go to the fuel pump in the tank to bypass the regulator. That o-ring is to replace the one when removing the fuel pump assembly behind the passenger side I would assume.
Old May 7, 2007 | 09:52 AM
jpc350z's Avatar
jpc350z
Do you have the dyno chart with A/F..?
Old May 7, 2007 | 09:58 AM
NS_350GT's Avatar
NS_350GT
Son of a *****!! I think im missing something... Heres there pic from the website.
Old May 7, 2007 | 10:02 AM
abyss's Avatar
abyss
open da lil white box. it looks like its all there.
Old May 7, 2007 | 10:04 AM
NS_350GT's Avatar
NS_350GT
White box is just the gauge.
Old May 7, 2007 | 10:08 AM
NS_350GT's Avatar
NS_350GT
anubyss, sorry for jacking your thread.
Old May 7, 2007 | 10:24 AM
anubyss's Avatar
anubyss
No problem NS 350GT . I won't be able to post the dyno charts until I get home tonight. After 6400, the a/f starts to climb above 12.
Old May 7, 2007 | 10:56 AM
MUZZY's Avatar
MUZZY
yea I was like WTF >< another $500 needed mod. but tell you what. it makes a world of difference. The stock regulator in the fuel pump assembly comes out and the return line takes its place. in the second picture. its the thing all the way to the right. and yes it comes with a rising rate regulator. you adjust it to give you more fuel per lb of boost.
also the 440 injectors are plenty. you dont need bigger ones.
what is stoping you from geting fuel was the stock regulator not the injectors.
easy install over all.
Old May 7, 2007 | 11:15 AM
anubyss's Avatar
anubyss
It looks like I just need a bit more fuel so 550cc injectors might not be necessary. I am going to order up the basic return line kit and see what the a/f does up top. Hopefully I can play around with Utec and do the minor tuning myself .
Old May 7, 2007 | 12:39 PM
MardiGrasMax's Avatar
MardiGrasMax
With out a boost referenced fuel pressure regulator the 56psi of fuel pressure you are seeing in the rail is reduced by what ever the boost pressure is in the manifold becasue the fuel pressure has to push against the boost pressure when the injector is open.
Old May 7, 2007 | 12:44 PM
Nexx's Avatar
Nexx
are you running a revup? if not is there any reason to be so concerned since the limiter on the 287 motor is at 6500rpm.
Old May 7, 2007 | 12:55 PM
anubyss's Avatar
anubyss
I have the limit set to 7100 with the AAM reflash. It's not just that, but also I really don't want to be at the limit for anything. Once I find out what the injector duty cycle is, I'll decid whether or not bigger injectors and necessary. I'd like for it to be around 80% duty cycle at max.
Old May 7, 2007 | 01:15 PM
anubyss's Avatar
anubyss
I have a rising rate fuel pressure regulator but it's either not working at all (won't let me turn the pressure up or down) or the stock regulator is interfering with it. So the best solution would be to just remove the stock regulator. I should have the AAM basic system by Friday so I can install it on Saturday.
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
