Upgrading Radiators
Old May 11, 2007 | 04:58 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by Q45tech
The ecu has a equation to decrease ignition advance when coolant increases beyond ideal [174-195F] usually 1 degree per 5F limited to 5 degrees retard at 220F.
Part of summer overheat protection.
Where did you get that info? Service manual?
Old May 11, 2007 | 05:04 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I think you can test it with cipher. Cipher has a function to trick the ECU into thinking the coolant is at X temperature.
Edit:
source: http://www.uprev.com/text/updates.html
Old May 11, 2007 | 05:06 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Originally Posted by RudeG_v2.0
There is a direct bolt on aftermarket radiator for the G. SGP got Power to make one for them. Here's the link from G35driver.com.
http://g35driver.com/forums/showthread.php?t=128757
I hope this helps.
It does, but the fitment on that one is not perfect, according to the thread. I'll have to look into it a bit more. Thanks for the link!
Dave
Old May 11, 2007 | 06:13 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
If this is correct, then its a good thing that Eaglegreen and many of our customers are running the FCON....as the stock ECU has zero control over ignition timing and fuel.
But honestly, during cold start, and cold operation, the ECU advances timing, so wouldnt it make sense, that the ECU would actually advance the timing when coolant temps are below optimal?
SharX59
Sep 30, 2015 10:54 AM
