vortech FAQ: read this before asking vortech questions
Old Mar 29, 2009 | 10:20 PM
  #361
evobunny's Avatar
evobunny
Is the only way to bump up the rpm idle is to go to nissan. or is there something u can do yourself. sorry for the dumb question but nissan sucks ***** where I live. they dont like me.
I just install my vortech, and got that annoying rattle below 900 rpm
Old Mar 30, 2009 | 03:13 AM
  #362
Car vs. Driver's Avatar
Car vs. Driver
Dealer or tuner that can flash the stock ECU are your only options ...
Old Mar 30, 2009 | 10:13 PM
  #363
evobunny's Avatar
evobunny
do you know how much a dealer would charge. and how long it would take. and also I have the unichip with my vortech full kit. would dealer know how to raise it if I have that.
Old Mar 30, 2009 | 11:07 PM
  #364
Car vs. Driver
Probably an hour of service ... $80 or so.
Old Mar 31, 2009 | 10:02 AM
  #365
jpc350's Avatar
jpc350
Or you could by a cypher for about $100.0 I believe and bump it yourself to about xxx rpm...Check search on cypher (sp.) and get all the info...GL
Old Mar 31, 2009 | 04:40 PM
  #366
evobunny's Avatar
evobunny
humm anyone else know about this method.
Old Mar 31, 2009 | 05:11 PM
  #367
Car vs. Driver
Cypher cable is $299 new ... not $100.
Old Mar 31, 2009 | 05:13 PM
  #368
Chef-J's Avatar
Chef-J
Booooosstt!!
http://www.uprev.com/
Old Mar 31, 2009 | 05:32 PM
  #369
OldManZ350's Avatar
OldManZ350
CIPHER DATA & DIAGNOSTICS
Our popular data logging and diagnostic tool for today’s Nissan and Infiniti vehicles. Cipher allows you to connect your USB equipped Windows PC directly to your vehicle and communicate with on-board systems such as the ECU.
With Cipher, you can log various sensors/parameters and retrieve DTC (Diagnostic Trouble Codes) so you can see how your vehicle is running and see what needs to be repaired or adjusted. Data that is retrieved with Cipher can be viewed in real time or saved to a file for later viewing or comparison. Cipher’s .csv files can be viewed through Cipher’s built-in graphical display or through many spreadsheet programs.
Cipher
$300
nice tool
go to uprev.com
Old Apr 3, 2009 | 06:25 AM
  #370
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
whats up guys!
I just got a killer deal on a vortech tuner kit with utec and DW 600cc..
I have a couple of question though..
the easiest question is:
Where can I find/ buy the 2.87 pulley??
- I plan to do the install myself ( with the help of some peoples threads like chef-j and car vs driver ( great info ) ) after all is done, I plan to take the car down to AAM and have jeremy tune the utec..
- Do I need to trailer the car down there? ( 4-5 hr drive ) Ive read that if I dont install the supercharger cog belts I should be fine and drive the car like N/A. Confirm?
- Whats a good belt that you guys recommend ? Gates? any link to where I can buy it? ( ill keep searching ! )
I found a great deal and I spent around $4600 for everything: polished blower- 3.12 & 2.87, utec, DW600cc, gtm pulley mod, walbro 255, aam oil pan spacer, greddy catch can, nismo thermostat.
already have : 5/16 spacer/ test pipes/ nismo catback/ 1 setep colder plugs - engine wise.
do you think with my setup i can hit 400+ whp??
Thanks a lottt for those who may help me with the questions!
Old Apr 3, 2009 | 06:46 AM
  #371
Car vs. Driver
Originally Posted by Vas@Extended
whats up guys!
You can get it from Vortech, they're like $80-$90 IIRC. Or, check the classifieds on here.
Good for you, DIY is the way to go.
Driving it shouldn't be a problem even with everything hooked up. Just don't go into boost and you'll be fine. I mean, it'll run pig rich but that shouldn't hurt anything.
AAM should be able to send you a base map that you can load to your UTEC though. FunctionTUNED sent me one for my drive out to him.
Yep, Gates.
400WHP on the AAM dyno shouldn't be a problem with that setup. Good luck!
Old Apr 3, 2009 | 06:54 AM
  #372
Vas@Extended
Thanks bud!
Old Apr 3, 2009 | 09:08 AM
  #373
Chef-J's Avatar
Chef-J
Booooosstt!!
Or you can look up FIXED: www.superchargersonline.com
I just fixed one problem, i will post on my thread, check that out.
Edit: Car vs driver,
Do you still interetsed in my HFC? if do, send me a your phone number, i will call you on tuesday.
chefj
Old Apr 3, 2009 | 09:25 AM
  #374
Vas@Extended
Sounds good Ill be checking that out... im mostly concerned about driving the car for 5 hrs.. Im sure it will be no problem( hopefully! ) ill just stay below 3000-3500 rpm.
if I were to just not install the supercharger cog belt and just drive it normally.. would that be ok?? since it is my daily driver and I may need to drive it around to get me places.Thanks!
Old Apr 3, 2009 | 09:39 AM
  #375
Chef-J's Avatar
Chef-J
Booooosstt!!
Well, you can unhook the cog pulley and drive. I didn't install utec yet and still running with N/A belt setup. No problem just like N/A but eatting alot of gas tho lol
chefj
Old Apr 3, 2009 | 09:52 AM
  #376
Vas@Extended
chefj
Oh so you got the stock belts, you didnt put the supercharger belts back on?.. why is it eating so much gas? are you on bigger injectors? ( checking your thread now )
I was thinking.. to put the utec and everything so when I get to AAM, they dont charge me for like labor and such ya know. I would like to do everything my self.
But it looks like either way ill drive, that will save me a bunch load insted of trailering it
Old Apr 3, 2009 | 09:58 AM
  #377
Chef-J's Avatar
Chef-J
Booooosstt!!
I don't know why this is eatting so much gas tho lol maybe my drive style changed? lol
Well, this is my first time doing it. I didn't want to mess around wtih utec and all this fuel stuff + didn't have enough time at that time.
I rather pay more and be safe hahah
And yea i'm just running stock belts, and GTM shipped their GTM pulley and belts to the shop so i have a only cog belt. ( i lost my 3.33 pulley belt during the moving out from my apartment)
Like car vs driver mention it,
- you can get a base map from AAM
- unhook the cog belt and drive
Either way you will be fine.
Edit: When are you going to install??
chefj
Old Apr 3, 2009 | 10:06 AM
  #378
Vas@Extended
chefj
Cool thanks for info!
Does GTM carry the gates belt for the 2.87? that be good cause I cant find em anywhere lol... this way I'll just contact George.
I plan to do the install when I get the supercharger back from vortech ( I will be sending it out for a minor rebuilt of new seals and bearings ( just to be safe ) so I dont take it out later if anything happens.
should be in the next 2 weeks
Old Apr 3, 2009 | 01:08 PM
  #379
Car vs. Driver
You could just not hook up the blower belt and drive up like that, it's up to you. I would personally (and did) have everything installed, hooked up, ready to go and drove about 2.5 hours from my house to FunctionTUNED. No problems what-so-ever.
Just drive like an old lady, resist the urge to floor it and you'll be perfectly OK.
Old Apr 3, 2009 | 01:13 PM
  #380
Chef-J's Avatar
Chef-J
Booooosstt!!
I'm pretty sure they do. When i was ordering GTM pulley, George told me they need to know what pulley i will be running, so they can send out a right belt.
Btw, that's good idea to send your blower to vortech.
chefj
