vortech FAQ: read this before asking vortech questions
Old Apr 30, 2023 | 06:48 AM
  #2281
MeSs's Avatar
MeSs
Originally Posted by i8acobra
Did you use OEM Nissan sensors? It's been proven that the ECM doesn't like aftermarket sensors. Use OEM. Also, check the codes and make sure you don't also need a crank sensor.
Thanks for the reply.
The sensors should be OEM, Z1 Motorsports site says OEM. The old one's work, it's just that one of them gave me a error code sometimes. Since I had to replace the valve cover gaskets I replaced both sensors at the same time.
Will check error codes.
Old Apr 30, 2023 | 03:12 PM
  #2282
MeSs's Avatar
MeSs
Update. I reset my ECU, all error codes gone. Car is working as it should now 😊
rx7/350z
Jan 16, 2013 12:11 PM
Hollywoodfraser
Sep 7, 2005 03:14 PM
g8tor20
Jul 30, 2005 08:32 AM
kevinapex
Jul 29, 2005 06:26 AM
