vortech FAQ: read this before asking vortech questions
Old Mar 8, 2009 | 12:42 PM
  #341
Bahraini350Z's Avatar
Bahraini350Z
SS box was fine with me using 2.87 pulley with stock injectors. It produced 395whp on pump gas and A/F ratio bellow 11 at redline.
I know many will disagree with me, but I've been tracking this car (circuit racing) for a year with no problems at all.
Old Mar 11, 2009 | 01:04 AM
  #342
evobunny's Avatar
evobunny
is there a break in time for the charger. how long did you baby it. i also heard you had to let it idle for a while when you first start up.
Old Mar 11, 2009 | 05:14 AM
  #343
Car vs. Driver's Avatar
Car vs. Driver
Warm up your car as you normally would ... don't hammer on it until it's up to temp.
No break in required on the vortech.
Old Mar 11, 2009 | 07:31 PM
  #344
evobunny's Avatar
evobunny
sorry I mean when you first install the kit. did you have to break it in. like put some miles on it before you floor it. I heard very first crank up you should let idle for like 10 min before you rev it up or drive it.
Old Mar 11, 2009 | 08:18 PM
  #345
Chef-J's Avatar
Chef-J
Booooosstt!!
I would let it warm up before they rev high.....
Old Mar 12, 2009 | 05:02 AM
  #346
Car vs. Driver
Ideally, you should prime the oil system before letting the car actually start. What I mean is, crank the motor to get oil into the blower without the car starting. Then, start up the car, check for leaks and you're good to go.
Old Mar 12, 2009 | 07:14 PM
  #347
evobunny's Avatar
evobunny
oh ok. well i had order the v-3 would i still have to do this since it is self lube
Old Mar 12, 2009 | 07:58 PM
  #348
fowlman01's Avatar
fowlman01
For the California people: I passed the Cali smog requirements with my Vortech. If you can pass here you can pass anywhere. All emission readings were as low if not lower than an N/A 2003 350Z.
Old Mar 13, 2009 | 06:10 PM
  #349
evobunny's Avatar
evobunny
is there a link to a online install manual for the new v-3 for a 2006 non rev up
Old Mar 14, 2009 | 02:17 AM
  #350
Xendric's Avatar
Xendric
Installation manual
Old Mar 14, 2009 | 02:47 AM
  #351
evobunny's Avatar
evobunny
Originally Posted by Xendric
which instruction should I should follow for a 2006 automatic.
Old Mar 14, 2009 | 04:33 AM
  #352
Xendric's Avatar
Xendric
I think 2006 auto's had the 280hp motor, non-revup.
So I think you should follow the 03-05 guide.
Old Mar 14, 2009 | 01:29 PM
  #353
350z006's Avatar
350z006
Congrats dude!....did you still have your stock injectors and stock cats?
Old Mar 14, 2009 | 08:28 PM
  #354
fowlman01's Avatar
fowlman01
Yes. I was still worried because I had to go to a Test Only shop. They just took the CARB # off the Vortech and asked what the hose was that came off the oil breather. ( I have an oil catch can). They looked under the car too, so they would have probably caught any aftermarket cats or test pipes.
Old Mar 16, 2009 | 09:01 AM
  #355
350z006's Avatar
350z006
How come you had to go to a test only place? Did you get pulled over?
Old Mar 16, 2009 | 03:38 PM
  #356
fowlman01's Avatar
fowlman01
Me! get pulled over???? hahaha No, They don't pull over old guys driving a modded Z. That is one of the few benefits of being old.
That is what it said on the renewal. Test Only shop. The guy there said that they randomly pic cars for a Test Only. It tested really well.
Old Mar 22, 2009 | 02:12 AM
  #357
evobunny's Avatar
evobunny
ok I have a 2006 automatic 350z, I was looking over the wire section of the online manual. http://www.vortechsuperchargers.com/...s/4NZ218im.pdf .havnt got my kit in yet. Do I skip over section 10 and just do section 11.
And for the MOUNTING PLATE INSTALLATION do I follow section 5 or 6.
Sorry for the noobie question. but the 06 automatic is like unclear. since they said 2003- 2005 and then 2005 and Later “Rev-Up” Engines
are they saying 2005 and later and rev-up engines when they said 2005 and Later “Rev-Up” Engines
And I order the v-3 blower full kit if that makes any differents
Old Mar 26, 2009 | 01:10 PM
  #358
Chef-J's Avatar
Chef-J
Booooosstt!!
Originally Posted by sentry65
- I recommend getting an oil catch can and get a checkvalve installed with it. It'll save you the hassle of having to clean oil from the inside of the piping and intercooler should you get some oil blow-by. It'll also prevent oil from going back into the piston chamber which can possibly cause preignition or detonation. IMO it's money well spent and not all that expensive in the whole scheme of things
Vortech owners, any recommand brand of catch can?? or any link would be good. I remember i saw one thread was talking about catch can with vortech setup, but i can not find it again.
Thanks.
chefj
Old Mar 27, 2009 | 10:04 PM
  #359
evobunny's Avatar
evobunny
I need unichip instruction for a 06 350z automatc. mine didnt come with one
Old Mar 28, 2009 | 12:12 AM
  #360
evobunny's Avatar
evobunny
anyone have a pic of there fuel pump relay set up for the unichip.. please help. How did you run red and the brown wire from the in side of car to the relay.
