View Poll Results: What would you do.
Buy a new Turbonetics Turbo
13.43%
Install a custom GT35 water-cooled Turbo
45
67.16%
Remove the kit and go NA for now
13
19.40%
Voters: 67. You may not vote on this poll
Vote what to do.
Old May 13, 2007 | 06:21 AM
Zivman's Avatar
Zivman
Originally Posted by TENGAI
Drop a GT35R on there and boost the **** out of it. TT is the easy way out, and while a strong GReddy / APS setup can be monsterous, most of the dyno's we see on the boards from typical installs are in the 500-550 range. That's an EASY mark with a proper setup on a Garrett 3582R. Biggest concerns are fuel and ems. But even the TT guys have to properly address those areas to hit big numbers.
Just food for thought.
You are leaving out the fact that if he attempts to run that turbo, he will likely have issues with backpressure tryng to make any decent amount of power. he will be very limited with the exhaust dump off the turbo. to get into the 500's on a single, I would think you would need at least a 3" dump off the turbo
Old May 13, 2007 | 11:19 AM
redline350ZZ's Avatar
redline350ZZ
If I do the GT35 I will try to fit the largest pipe possible and dump it asap. I like the Jun 350Z fender exhausts and am looking into something like that.
Old May 13, 2007 | 01:10 PM
Zivman's Avatar
Zivman
If you have a shop that can do it, go for it. that said, I think you will have a hard time even fabbing up a 3" pipe and still not have enough flow. On top of that, cramming in the bigger pipe will probably only lead to more heat issues, melting lines, etc when you go for more power.
Old May 13, 2007 | 01:23 PM
Fluid1's Avatar
Fluid1
Like on the SR20's in the older B13's, I believe that a pipe that goes about .5" higher than the bottom of the oil pan should be sufficient. Have a small angle at the end, voila.
Old May 13, 2007 | 01:53 PM
redline350ZZ
Well no Intake, cats or Y-pipe. NA will cost money too.
Old May 13, 2007 | 03:50 PM
TENGAI's Avatar
TENGAI
Nothing's going to be easy or cheap. Custom kits are expensive no matter which way you go and you're going to have to address more problems the higher you go in whp...
Patience, money, and time cure all related woes
Old May 29, 2007 | 12:44 AM
Havok_RLS2's Avatar
Havok_RLS2
I don't think it'll be a difficult as everyone makes it out to be.
Old May 29, 2007 | 09:41 AM
redline350ZZ
Car is NA for now.
350Z_Al
Oct 29, 2020 07:44 PM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
ablaine
Nov 29, 2016 10:13 AM
Mattg350z
Oct 2, 2015 06:51 AM
Tochigi_236
Sep 27, 2015 03:40 PM
