Max HP Out Of A Walbro 255?
Old May 20, 2007 | 12:32 AM
JETPILOT's Avatar
JETPILOT
Default Max HP Out Of A Walbro 255?
How much power can I get out of the single in tank walbro 255? for 525whp will I need any fuel system modifications other than the return fuel system and the 255 pump?
JET
Old May 20, 2007 | 04:51 AM
Q45tech's Avatar
Q45tech
Research the effects of voltage at pump terminals [wire size vs current draw] and pressures above 43.4 psi and how in DECREASES total flow and pump life.
http://www.roadraceengineering.com/f...pflowrates.htm
For reliable long term operation be sure the pump or parallel pumps are only operating at 50% of peak capacity.
http://www.fuindustries.com/supra/MK...lculations.xls
Old May 20, 2007 | 05:14 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I believe Sharif hit 622 on a single Walboro. Not that's it's reccommended.
Old May 20, 2007 | 05:33 AM
QuadCam's Avatar
QuadCam
if you go with HUGE injectors, then you can run at a lower Fuel pressure which helps with the pump. Fuel pumps can eliver more fuel at lower pressures than at higher ones......the opposite is true of injectors.....injectors flow more at higher pressures..........
that's why I say use HUGE injectors (like 1000cc units) if you are going to try and maximize a singel walbro 255
Old May 20, 2007 | 05:51 AM
westpak's Avatar
westpak
SFZCC
^ good point, I am using 750cc's and brought the idle pressure down to 38-40 with vacuum attached and no issues so far at 554 on a Mustang dyno.
Old May 20, 2007 | 07:41 AM
failsafe306's Avatar
failsafe306
On 1000cc's, I was at 550hp/560tq to the wheels, with plenty of fuel left. Only thing holding me back was octane.
Old May 20, 2007 | 07:46 AM
mario23's Avatar
mario23
That's good to know. That means there's other cool stuff I buy now and do the return later when I push REAL numbers
Old May 20, 2007 | 08:09 AM
failsafe306
Nobody's saying not to get a return fuel system.
Old May 20, 2007 | 08:54 AM
mario23's Avatar
mario23
I know. But its also not imperetive that I get one now ahead of some other mods I'd like to get under the hood. At my conservative boost settings I don't need that return yet.
Old May 20, 2007 | 10:26 AM
turismo's Avatar
turismo
JET
Im not sure though, but I think there are two version of the Walbro, high pressure and high volume!
Old May 20, 2007 | 12:09 PM
Q45tech's Avatar
Q45tech
A normal oem fuel pump last at least thru 70k/6 year warranty [Infiniti] most 120k depending on the cleanliness of the fuel you buy.
Water in ethanolized fuel can decrease functional life significantly.
Increasing operating psi above 43.4 increases current draw and decreases operational life.
Not sure if members consider 1 year a satisfactory life vs 5 years?
Old May 20, 2007 | 12:18 PM
diwun67's Avatar
diwun67
Subscribing to this thread with a great question Thank God the fuel pump is so easy to get to in these cars lol
Old May 20, 2007 | 01:02 PM
QuadCam's Avatar
QuadCam
isn't that the truth!
Old May 20, 2007 | 01:08 PM
diwun67's Avatar
diwun67
Well you know something has to be easy, everything else is a PITA to get to in a Z/G
Old May 20, 2007 | 01:09 PM
QuadCam's Avatar
QuadCam
actually, I think this is the easiest car I have ever worked on....
Old May 20, 2007 | 01:12 PM
diwun67's Avatar
diwun67
Actually yeah you're right, I guess I was referring to how hard it is to work on a Z/G with a TN kit lol
Old May 20, 2007 | 02:22 PM
minus500's Avatar
minus500
Has anyone tried using a fuel pump booster to increase max hp? If this worked well, it would be an inexpensive solution to increase fueling. I don't know much about them so tuners chime in with your experience please.
Old May 20, 2007 | 02:31 PM
westpak's Avatar
westpak
SFZCC
That is how the Jim Wolf TT kit handles the fuel, it has its limitations trying to go for higher HP since it is not tunable.
Old May 21, 2007 | 06:07 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
525whp is well within the safe limits of a return fuel system, walbro pump, and 650cc injectors. Go for it!
Old May 21, 2007 | 06:10 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
his car will be nice and fun to tune for sure. a brand new greddy kit installed correctly has sooo much potential!!
