Vortech power
Old May 22, 2007 | 10:56 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Default Vortech power
Vortech claims 440 hp at the crank for the revup. Just wondering if anyone has any actual numbers out of the box for this kit for the revup. Cheers. I have searched, but everyone i've seen has been with a tune. I would like to see one out of the box.
Old May 22, 2007 | 12:38 PM
THE TECH's Avatar
THE TECH
Probably need to do a bit more searching.
Old May 22, 2007 | 12:41 PM
robbycolli's Avatar
robbycolli
That would be around 370 at the wheel and that sounds right. Compare with my numbers below with a non revup and 10lb pully.
Old May 22, 2007 | 01:21 PM
b00stedjustin's Avatar
b00stedjustin
that's only roughly 344 whp (transmission loss) which is right on the money.
(most G's baseline at 223 whp but come with around 285 hp to the crank), so (223/285) x 440 = 344.256 whp. Correct me if I'm wrong.
Old May 22, 2007 | 01:29 PM
sentry65's Avatar
sentry65
the burninator
i don't think drivetrain losses on a RWD car are over 22%
I agree more with the 370whp estimate if the car is tuned
Old May 22, 2007 | 01:49 PM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Like i said, plenty of results, but none of them out of the box without a tune. That is what i am looking for. RWHP on a revup, out of the box with no tune. Any takers? Thanks
Old May 23, 2007 | 02:05 AM
sheck4's Avatar
sheck4
Default Interested
Also very interested in the answer, want to go SC with my 06.
Old May 23, 2007 | 04:30 AM
MUZZY's Avatar
MUZZY
im pushing 410rwhp right now and only running 9psi on a 287 motor so yea those numbers are correct.
Old May 23, 2007 | 04:31 AM
MUZZY's Avatar
MUZZY
all the money spent and cant dish out $500 for a good tune?
Old May 23, 2007 | 04:32 AM
350z2go's Avatar
350z2go
muzzy what did u upgrade besides the pully to get 410 whp????
Old May 23, 2007 | 05:22 AM
MUZZY's Avatar
MUZZY
AAM stage 1 fuel return
walboro 255
test pipes
3" exhoust
5/16 spacer
re-flash
a real good tune from Mike at AAM
440cc injectors
My setup is the safest I beleive. since I only have a stock block I wanted everything to be reliable and safe. hence did the research and chose vortech for 400rwhp goal.
I want to do headers and a kinetix manifold in the future and maybe cams. But I'm a DIY guy so anything to do in the engine im iffy.
Old May 23, 2007 | 11:33 AM
ReV2Red's Avatar
ReV2Red
I haz da turbos
Not quite mate. You find me a vortech tuner in Spain, and i will personally send you a tall blonde russian.
Old May 23, 2007 | 02:32 PM
abyss's Avatar
abyss
Send me da lolita and I'll be on da phone!
Old May 23, 2007 | 02:42 PM
MUZZY's Avatar
MUZZY
$hit! There have been tuners that have flown to europe before to tune cars. Im pretty sure we can get someone at performance factory to take a ride to spain.
none the less seriously I see your delema. If no tuning is available I would go with the vortech full 7psi kit. its a direct bolt on and safe out of the box. you will be in the 310-330rwhp range
Old May 23, 2007 | 03:04 PM
DMK's Avatar
DMK
walboro 255
test pipes
3" exhoust
5/16 spacer
re-flash
440cc injectors
In your opinion, was the return fuel necessary? What pulley are you running?
Old May 23, 2007 | 03:12 PM
MUZZY's Avatar
MUZZY
im running 9psi so yes the fuel return and walboro is necessary past 6500rpm
if you stay below them your stock pump and injectors are maxing out at this point. I have a stock block and tend to keep it. I wanted to be super safe and the Z is my DD and I take it to car shows every weekend I put over 2k a month in miles on it and I go redline 1 time a day at least. And it has been 7k now and still rides like day 1 with the vortech. Im loving it and my mind is clear since I know its geting enough fuel. My redline after a reflash is 7100rpm so there is more power up on top.
Old May 24, 2007 | 08:55 PM
Hexxum001's Avatar
Hexxum001
Hmmm . . . yeah I am also curious to see if anyone has dynoed their Vortech SC (full kit) Z/G with the RevUp motor right out of the box. I am very close to going with this set up myself.
Old May 25, 2007 | 02:27 AM
sheck4's Avatar
sheck4
Default Exactly
I want to do headers and a kinetix manifold in the future and maybe cams. But I'm a DIY guy so anything to do in the engine im iffy.[/QUOTE]
Exactly what I am going for......Thanx
Old May 25, 2007 | 03:43 AM
lone_Z's Avatar
lone_Z
Default awesome info....
rev thanks for asking the question and double for you muz for answering...
i have the same problem. i'm half way 'round the world and i've seen the work they do here... let me just say this one thing... "we have the same wheel you want. oh your car needs a 5x114.3and we only have 4 bolt patterns? no prob! we'll just drill another hole here...." umm yea.... these guys aren't going to do my tune. i have plenty of other fun/horror stories if anyone's interested.
yup, my mind's made up. i'm going to go for the vortech out the box since i have to go the diy route. now who do i buy from? hehehe... at least that'll be easy.
thanks again guys!
Old May 25, 2007 | 04:46 AM
MUZZY's Avatar
MUZZY
I got mine from audiablemayham he has the cheapest price guaranteed and great guy
oh I would splurge a little and get the polish kit also, because Thats what I would do if I could order it again. the satin is too dull
