turbo kit...?
Old Jun 7, 2007 | 06:49 AM
sean2006's Avatar
sean2006
Default turbo kit...?
hey guys i live in austin TX and i am trying to see if i should go with a turbo kit or NX i go school and work full time + house payment and all that but i manage to get around 5 to 6k and i would like to know if there is a way for me to do a turbo set up with that much money parts - tune - dyno and so on .... if not than uprev here in town said 2700 for a NX setup ......
Old Jun 7, 2007 | 07:31 AM
masterj26's Avatar
masterj26
What is included in the NX setup for $2700? If you are thinking about nitrous, I would contact Jeremy (Audible Mayhem) or Ryan (98intrigue) @ Performance Factory. They can set you up with everything you need.
5-6k isn't going to get you much when it comes to FI. you might be able to pick up a used TN single turbo kit and get it installed in that price range.
abyss's Avatar
abyss
Go for the Nitrous. Your gonna spent ATLEAST $10k for a turbo setup. $25k+ if done properly. So if you just got $5-6k scraped up and don't have $$ for a new motor laying around. FI=not wise.
Old Jun 7, 2007 | 08:07 AM
IIQuickSilverII's Avatar
IIQuickSilverII
25k...is not "if done properly" its if done with a build engine
10k and you can do a turbo kit ona stock block the rigth way.
but based on what your requirements are...Nitrouz is better option 4 u
Old Jun 7, 2007 | 08:13 AM
abyss's Avatar
abyss
but based on what your requeirements are...Nitrouz is better option 4 u
Built engine is 'done proplerly' with the VQ, or any motor not built for boost.
Old Jun 7, 2007 | 08:19 AM
taurran's Avatar
taurran
You people are paying way too much!
Old Jun 7, 2007 | 08:21 AM
sean2006's Avatar
sean2006
ya i mean uprev wants 12k for a full setup and with my house and school cant do that right now and i belive the the NX kit is with everything i mean everything i am getting a deatil on whats comes with it today you guys know what power 350z make with that ...? 100shot for now
Old Jun 7, 2007 | 12:56 PM
chris'smax's Avatar
chris'smax
that's were you are wrong. Bad tuning and $hitty quality parts are what lead to improper setups for a stock block or any motor for that fact.
There is a difference between doing things right and pi$$ing money away on items that are not required.
Old Jun 7, 2007 | 01:04 PM
rcdash's Avatar
rcdash
well, different prices for safe tunes to different whp levels. I did my homework on this and found:
"done right" to 380 whp is about $12k (TT kit, gauges, install, tune)
"done right" above 450 whp is about $24k (+built motor +cams +tranny +ECU +exhaust +cooling +extra labor)
"done right" for the track is about $34k (+brakes +wheels +suspension +cage)
Old Jun 7, 2007 | 01:05 PM
sean2006's Avatar
sean2006
so idk i mean there not going to use utech there going to flash the ecu and retune it ....? and the total coast with parts and tuen + dyno i belive is 2700 give or take ? and when i ask them what power should i be looking at nothing......
Old Jun 29, 2007 | 09:40 AM
josh846's Avatar
josh846
Sean2006, my car is at UPREV right now, taking off TN ST and going with fully built engine and Greddy TT. To be honest if you only have 5-6k you need to just use it on your house. Going with a turbo or nitrous kit, is going to cost you. Nitrous much less, but there is still a slim possibility of blowing the engine eventually, with turbo, you will blow it eventually, so you will need to have more money just sitting around for when that happens. UPREV has the best customer support and some really knowledgeable guys working over there. They have had my car for about 4-5 months just toying with it, I wouldn't let them mess with it, if they weren't capable. In Austin they are by far the best shop to take it to, they might seem a little higher at first, but you will see if you have the slightest problems they will take care of you no questions asked.
Old Jun 29, 2007 | 09:41 AM
josh846's Avatar
josh846
power wise, didn't you say you wanted a 100 shot? well guess what, you will get around 90-100 more hp, assuming you are only at 225-235 now you do the math. With TN you should have around 365-375, I was around 385-400 but I also have several other small things done.
Old Jun 29, 2007 | 09:48 AM
doug's Avatar
doug
so basically you are telling us that anyone can come down to PF and get a TT Setup, Built Motor, Cams, F Con, Koyo Radiator, Head Gaskets, 750cc Injectors, Return Fuel System, Oil Cooler, Clutch, Flywheel, Gauges, Installed and Tune for well under 20K?
Old Jun 29, 2007 | 03:41 PM
taurran's Avatar
taurran
Get a life man...
Old Jun 29, 2007 | 03:46 PM
doug's Avatar
doug
Get a life man...
so its safe to assume you are unable to answer the question
Old Jun 29, 2007 | 03:48 PM
taurran's Avatar
taurran
No, it's safe to assume that I'm sick of you bouncing from thread to threads instigating arguments and taking threads off topic. I could argue this and you would get basically what you want, to stir up the forums. You ARE a roach on these forums, just like you said.
Seriously, you need another hobby. Go build something out of posickle sticks or something, you worthless fa**ot.
Old Jun 29, 2007 | 03:50 PM
doug's Avatar
doug
let me get this straight.. you make a statement saying people pay too much.. then i ask you if where you have your work done has a better deal and your reponse to me is that i am a homosexual?
i am really confused as to what is going on here.. does anyone care to explain it to me.. i am lost.. i mean i never instigated an argument.. or said anything negative to Craig in this post and now i am a roach and a homosexual..
Old Jun 29, 2007 | 03:55 PM
skidmarq's Avatar
skidmarq
Is it a safe assumption to say that you two have had instances in the past where you don't see eye to eye?
r0mey's Avatar
r0mey
@ this thread
Old Jun 29, 2007 | 03:56 PM
doug's Avatar
doug
man i am lost.. i feel like the lady who found out her coffee was too hot at McDonalds
