For those of you with mods who had your ECU replaced...
Old Jun 7, 2007 | 12:14 PM
617G's Avatar
617G
Default For those of you with mods who had your ECU replaced...
How did you do it? Where? Who programmed they key? etc...
Thanks.
Old Jun 7, 2007 | 12:17 PM
Alberto's Avatar
Alberto
Cranky FI Owner
One Word---> Technosquare
Old Jun 7, 2007 | 12:20 PM
rcdash's Avatar
rcdash
There is a procedure in the service manual for reprogramming following ECU replacement. I have read it in these forums also... The dealer can probably describe over the phone also.
Alberto> I don't think he was asking about a reflash...
Old Jun 7, 2007 | 12:21 PM
sentry65's Avatar
sentry65
the burninator
dealer has to sync up the BCM, ECU and all keys together at once
Old Jun 7, 2007 | 12:23 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
If you are just replacing a bad ECU, then you will need to take it to the dealer and have your keys matched to the ECU, or the car wont start.
If you have an FCON, you will not need to do this.
Old Jun 7, 2007 | 12:26 PM
Alberto's Avatar
Alberto
Cranky FI Owner
OR...Techno can disable that feature (pretty sure they need your key) and you can swap between stock/other ECU's in your car. Just offering options here guys...
Old Jun 7, 2007 | 12:30 PM
617G's Avatar
617G
Hrm...does this procedure require the use of a Consult or can it be done without it? Rcdash...you mentioned that it's something you can do yourself???
Old Jun 7, 2007 | 12:36 PM
617G's Avatar
617G
Would the dealer program an ECU that I brought or would they require me to purchase from them? I'm a bit hesitant since my EU is connected to it...not to mention the twins, etc...I would bring my car to the dealer in the first place, but I don't want to pay for a tow and have them pretend to work on it and then say "o, sorry...you have all these mods. we can't help you" and still charge me
Old Jun 7, 2007 | 01:12 PM
sentry65's Avatar
sentry65
the burninator
they do it through the OBDII port with a consult II
Old Jun 7, 2007 | 01:18 PM
617G's Avatar
617G
ic...thanks
Old Jun 7, 2007 | 02:13 PM
rcdash's Avatar
rcdash
oh - had no idea they could do that. thanks for the info.
Old Jun 7, 2007 | 06:37 PM
KPierson's Avatar
KPierson
I believe that TS can clone your current ECU on to another ECU so that the 2nd ECU can be used in your car. I do not believe they can completely disable the transponder system (I may be wrong on this).
Old Jun 8, 2007 | 09:10 AM
Chebosto's Avatar
Chebosto
transponder? ie. GPS tracker?
Techno can clone ecus (i.e. copy your immobilzer code, but cant completely disable it. it auto associated itself with the key). i'm not quite sure what transponder system you mean.
Old Jun 8, 2007 | 09:15 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
I doubt they can clone a blown ECU.
Andy, you need to take it to the delaer with all of your keys. GL
Old Jun 8, 2007 | 09:28 AM
617G's Avatar
617G
That's what I thought...I just wanted to make sure. I also had doubts if they would swap out the ECU with one I brought in, but they told me they don't have a problem with that. Thanks Dave
Old Jun 8, 2007 | 10:25 AM
KPierson's Avatar
KPierson
transponder = immobilizer = IVIS = NATS
Back when I installed car alarms we called all security systems of this type 'transponder's systems, which required the $50 bypass module and a spare key.
Old Jun 8, 2007 | 10:33 AM
617G's Avatar
617G
do you file down the key so they can't use it when they break into the car?
Old Jun 8, 2007 | 11:04 AM
KPierson's Avatar
KPierson
In a 'best' case scenario the customer would purchase a new, uncut key to put in the car.
However, to a car thief its not going to make a difference if the key is cut or uncut, as all they really need is the transponder part - the mechanical lock is easy enough to get around.
That is why you hide the box really well, and make it very hard to get to.
Old Aug 7, 2009 | 10:40 AM
splitime's Avatar
splitime
Bringing back an old thread sorry.
From my understanding Technosquare can Completely disable the NATS requirement.
I know this is a reach... but is this DIY doable? I'm putting a VQ into a non-Nissan car.. and not having to get a key and reprogrammed once done with the build would be really really helpful. Also with the budget I'm on... doing the full ECU job with Technosquare isn't in the cards right now.
If someone has this info and is worried about a security issue posting it up. Please pm or email me to talk about it and confirm I'm legit. I need the information only for my build.
splitime on aim or splitime@gmail.com
Old Aug 7, 2009 | 11:33 AM
rcdash's Avatar
rcdash
you may wish to contact the UpRev folks also (uprev.com).
