Aps St Problem
Old Jun 15, 2007 | 08:42 PM
azula's Avatar
azula
Default Aps St Problem
So, I just got in from a nice joy ride but it kinda sowered towards the end. I went under boost in 4th gear and i felt a jerk and the boost that was building suddenly stopped, on my way home i tried to go under boost but it wouldn't boost. the engine is running perfectly fine, there is no smoke. The car just won't boost any more, so technically, it feels stock. No warning lights came on or anything like that.....when I rev the engine, the turbo doesn't kick in....sounds like a simple problem (i hope)....maybe something came loose down there? help guys!
Old Jun 15, 2007 | 10:08 PM
andyisphat2004's Avatar
andyisphat2004
had a similar problem with TN kit. The pipe from the turbo to the intercooler popped off
Old Jun 15, 2007 | 10:28 PM
wongy's Avatar
wongy
yea that happened to me too, the pipe to the intercooler fell off, just get it fixed and use a better clamp
Old Jun 16, 2007 | 06:12 AM
azula's Avatar
azula
thanks guys...just wanted to make sure it wasn't a big problem...
Old Jun 16, 2007 | 06:43 AM
original786's Avatar
original786
keeep us updated to see what the problem was
Old Jun 16, 2007 | 11:27 AM
azula's Avatar
azula
ok, so i drop off my car today at dynamic turbo to get checked out and it turns out that my air intake filter was detached. I had them reattach the filter and i got an oil change. the problem is that the guy is also telling me that my oil seals are bad and that my intake had a puddle of oil in there. he said that i would have to basically rebuild my turbo to fix that.....is this true?? do i have to get the whole turbo rebuilt??? this sucks!
Old Jun 16, 2007 | 11:58 AM
westpak's Avatar
westpak
SFZCC
Well if you are not getting any oil out the exhaust then they are probably fine, the oil might have been left over from when you had the check valve issue.
Also please tell me they only filled up the oil to the L or low level on the dip stick, otherwise you will have issues.
Old Jun 16, 2007 | 01:11 PM
azula's Avatar
azula
hey gus! I was hopin u would post...lol. are yall closed today? I would have come to u guys but no one was anwering the fone. I forgot to tell them to fill the oil to the L line but I just picked it up and it is running fine...the guy at DT insists that my turbo seals are bad so I need to get my car up to u guys to check it out...and there is no oil leaking from my exhaust...however the guy said they found oil inside my intercooler pipe....wat u think?
Old Jun 16, 2007 | 01:25 PM
westpak's Avatar
westpak
SFZCC
I just got back into town, and the shop is closed today. Like I said the oil is probably from the previous issues with the check valve not anything new, if the seals were bad you would get smoke out the exhaust, and I forgot your was an ST so the oil level is not an issue as it is with the Twins.
Old Jun 16, 2007 | 01:35 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
no that happend to us when we put one in and the oil pump stayed on and didnt pulse, your turbo is bb so you might be fine the car that happened to us with is still running and the turbo is fine.
Old Jun 16, 2007 | 01:54 PM
azula's Avatar
azula
ok, what i'll do is keep an eye out for any leaking oil out of the exhaust, will it be significantly noticeable or should i inspect after each drive? thanks gus.
Old Jun 16, 2007 | 03:43 PM
westpak's Avatar
westpak
SFZCC
If it is that bad you will prbably see oil dripping down by the turbo/exhaust flanges. If the seals are leaking you would see smoke coming out of your exhaust during driving and/or idling. The oil they saw was probably from the initial issue you had with the check valve which allowed oil past the seals and into the tubing.
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
