Turbonetics water cooled turbo installation thread.
Old Jun 26, 2007 | 02:51 PM
taurran's Avatar
taurran
Originally Posted by VIZAGE
Very nice write up. Seems easy enough.
What's the lastest dead line for your car to be up and rinning?
Mine? I'm hoping sometime next month. I'm not going to rush it by any means, but I'm still waiting on parts.
By the way, all the pictures with the motor in the bay were from 2 months ago. The car currently has no motor.
Old Nov 11, 2019 | 06:04 AM
Tim Ritter's Avatar
Tim Ritter
I do have two questions following up on this. I'm running a rear mount STS kit. I have all the lines, fittings, and scavenge pump. I dont see a scavenge pump in use here.
Being that it's a rear mount set up, would it be necessary to install a scavenge pump? Or will the water pump provide sufficient pressure to send and return coolant?
Also, passenger coolant piping is the return? And driver side piping is the feed?
Old Nov 11, 2019 | 09:23 AM
bealljk's Avatar
bealljk
Welcome to the forum Tim - I would run a scavenge pump on seeing that you're rear mount. I speculate the OP didnt run a pump bc it's such a short route and smaller lines.
I thought driver side was the return and passenger side is the feed (if I remember correctly and I'm pressure sure this is how I hooked mine up)
I'm mixed emotions Tim ... you bumped a 12year old thread but you obviously did some searching...
Old Apr 3, 2021 | 04:10 PM
Ronjonsilver's Avatar
Ronjonsilver
Default Pictures no loading
Hello everyone, my first time here on the form.
​​​​​​I am working on fabricating my own turbo kit with a turbo that is water cooled. Thankfully i came across this post to help me out since i am not sure how to go about it.
Unfortunately, the pictures are not loading up and I am just wondering if there is a way to see the pictures that were attached to the main thread and also if that tee and water lines are available for sale individually.
Any help is appreciated, thank you!
350z82
Oct 1, 2015 06:25 PM
