03' stillen supercharger kit..
Old Jun 26, 2007 | 06:58 AM
riskyZ's Avatar
riskyZ
Default 03' stillen supercharger kit..
I have found an 03 G35 with the stillen sc kit already installed that I am thinking about getting, I know they put out anywhere from 340whp-365whp or somewhere around there what I am wondering is if you throw a mild cam into that equation will it make a big difference HP wise?
Old Jun 26, 2007 | 08:50 AM
Triple8Sol's Avatar
Triple8Sol
Cams will make a reasonably significant difference with this kit.
Old Jun 26, 2007 | 02:33 PM
one1pitchblackz's Avatar
one1pitchblackz
Depending on the stage your looking more at 280-320
Old Jun 26, 2007 | 02:40 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Cams might help a little but i made 340rwhp but that was on a dynapack which i hear runs on the high side.I would think about realistically 315rwhp but oooooooooooh the torque is amazing.
Old Jun 26, 2007 | 03:21 PM
FrickU's Avatar
FrickU
You can not get more than 340whp out of that kit even with cams, meth, yada yada yada. The supercharger just creates heat after 10lbs of boost.
Old Jun 26, 2007 | 09:16 PM
riskyZ's Avatar
riskyZ
wow i didn't know the kit was that weak...... wow theres almost no point unless you can do the work yourself... just to expecive for such a small gain...i want my 300zx tt back lol
Old Jun 27, 2007 | 02:12 PM
superchargedg
Damn Noobs
It is really not that weak,it has a very hard pull to it from off idle to about 5500 rpm,s and that is when it falls on it,s face.Even with stage 4 it dosent produce any more power above 5500 rpm,s but if you like stop light to stop light races it friggen awesome.The way it produces torque down low and thru the midrange is great but a turbo set up will kill it.I still like the kit and it is easy as hell to install and not need tuning but if higher power is your goal you wont see it with this kit.
350Z_Al
Oct 29, 2020 07:44 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
kyin
Oct 15, 2015 05:54 AM
Nicky R
Sep 20, 2015 01:05 PM
Calinismo350z
Sep 14, 2015 04:04 PM
