attn: engine builders..... how loose do you build your motors???
Old Jun 29, 2007 | 08:44 PM
go-fast's Avatar
go-fast
high silicon pistons have virtually no growth so vq bore should be max 95.530 after a fresh hone , wear limit is 95.730 and can be run if you dont mind a little slap.95.730 with standard pistons lifespan..... who knows.one way to maximize life is to avoid too short of a piston skirt in a loose motor,it will help with rock.if its too loose you might even want a piston that does grow.somtimes the best part isnt always the best choice!
Old Jun 30, 2007 | 05:54 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by go-fast
low/no silicon pistons have virtually no growth so vq bore should be max 95.530 after a fresh hone , wear limit is 95.730 and can be run if you dont mind a little slap.95.730 with standard pistons lifespan..... who knows.one way to maximize life is to avoid too short of a piston skirt in a loose motor,it will help with rock.if its too loose you might even want a piston that does grow.somtimes the best part isnt always the best choice!
It's actually the other way around. Zero Silicon and low silicon pistons expand MORE than high silicon content pistons. Our factory pistons contain high silicon, and as such, require very small piston to wall clearnaces of about .0015
Old Jun 30, 2007 | 08:25 AM
Zivman's Avatar
Zivman
I was told stock is around 2.5 thousandths and that most forged manufacturers recommend 3-3.5. Mmost builders seem to run 4-4.5, some even as high as 5.
Old Jun 30, 2007 | 08:57 AM
MardiGrasMax's Avatar
MardiGrasMax
Sharif, Since your here, can you tell us your piston ring gap strategy?
Old Jun 30, 2007 | 10:56 AM
Sharif@Forged
Forged Performance
Every engine builder is going to have a difference strategy...its much like an engine break-in strategy. Ours isnt necessarily any better than someone else's, it just how we prefer to build them. The gap is very depedent on the type of ring used; Chrome, iron, steel..etc..etc. It is also highly dependent on how the engine will be used; turbo, nitrous, track usage, NA all have different strategies. So I would rather not throw out numbers, becuase there isnt one proper gap for all pistons, rings, and usages.
Old Jul 1, 2007 | 08:59 AM
go-fast's Avatar
go-fast
im a dysletic typer my bad
wanderingstuden
Jan 28, 2016 07:03 PM
Fixxxercask
Nov 9, 2015 11:10 AM
