Help me out boys Dyno Results F*&^_&!
Old Jun 29, 2007 | 11:41 AM
clemlover15's Avatar
clemlover15
the current shop fixed a lot of problems the the SP AEM had, trust me they are a great tuner, I think the exhaust might be keeping me back??
I need more info like what gear they ran in, maybe that dyno reads low, A/F there are a tons of questions to ask.
I am getting the car tonight and going to get it dynoed at other places for sure.......
I'm not going to give up I know what this should make.
Old Jun 29, 2007 | 11:52 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
idk man. either something is wrong with your install/car or the tune sucks... take your pick.
Old Jun 29, 2007 | 12:13 PM
warmmilk's Avatar
warmmilk
they could have dyno'd ur car in 4th gear, most people dyno in 5th cause of the 1 to 1 ratio, 5th gear puts down more power
or maybe its just a low reading dynojet. remember a dyno is just a tool, the one true dyno is trap speed, take it to the track and see what it traps at then compare to similarly modded cars' trap speeds
Old Jun 29, 2007 | 12:16 PM
Gman2004's Avatar
Gman2004
The last time I dyno'd my car I did both a 4th and 5th gear run. 5th gear was only 20whp more than
4th. It's not a huge difference between 4th and 5th.
Old Jun 29, 2007 | 12:19 PM
Chris@SP's Avatar
Chris@SP
Sound Performance
Andy, have them email larry and I the map
xxsupraxx@aol.com
chris@spracingonline.com
Aside from the cold start issue there shouldn't be any issues tuning fuel and ign, boost comp, etc. with the aem.
Also, did they do any logging with the aem? if so please send those, that would help a great deal.
Thanks
Chris
Old Jun 29, 2007 | 12:25 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
off topic but are either you or sp racing using the aem serial gauge?
Old Jun 29, 2007 | 01:17 PM
ht4's Avatar
ht4
Originally Posted by Gman2004
...your tuner has no clue what he is doing. His name wouldn't happen to be manuel? j/k
Old Jun 29, 2007 | 05:46 PM
clemlover15
update:
the reading pull was is in 4th gear,
A/F was 11.0:1 very steady AEM can do that great as well as control timing.
The tune was keep rich b/c boost could not be controled all the way, see below.
The graph is being emailed to me tomorrow, it starts off great it hits 13 psi not problem than boost starts to drop for some reason we can't hold boost @ 13 psi it drops off. If it wasn't for that we were easily on our way to 500+.!!!
Im not that worried any more.
To clearify the AEM from SP is great when driving and tuning it was doing that great as expected
-idle and cold start are still pretty ****y but better.
Old Jun 29, 2007 | 05:49 PM
doug's Avatar
doug
thats good... glad to hear you are feeling better
Old Jun 29, 2007 | 05:50 PM
stormcrow's Avatar
stormcrow
with only 400ft lbs of tq, something is amiss... with the smaller exhaust and cats, you should be getting back pressure which would allot for higher torque... what type of boost controller do you have?
Old Jun 29, 2007 | 05:53 PM
clemlover15
Originally Posted by ht4
I stand by my tuner he has tuned tons of cars way faster than mine, and all of my previous cars without any problems. Trust me, I trust them with my car any day of the week.
Old Jun 29, 2007 | 05:54 PM
clemlover15
greddy that may be the problem.
our the actuators may need to be adjusted what do you guys think?
Old Jun 29, 2007 | 05:56 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
wtf dude the AEM can control boost.. ditch the greddy and hook it up right
stormcrow's Avatar
stormcrow
i'm partial to the HKS EVC controller... but, the greddy profec e-01 (i'm guessing this is what you have?) should do the job... my turboxs manual did ok at 13psi... i can't imagine it would do any better than the profec...
Old Jun 29, 2007 | 06:00 PM
clemlover15
i'm thinking the actuators may be the issue here, not the Boost controler.
Old Jun 30, 2007 | 04:22 AM
BrianLG35C's Avatar
BrianLG35C
What color actuators are you running?
Old Jun 30, 2007 | 04:40 AM
Philthy's Avatar
Philthy
Boost Junkie
The VQ platform is very sensitive to back pressure and you'll continue to run around in circles unless you address that issue first. Like many have already stated, ditch your cats and get a good size down pipe and exhaust if you want to make big power...
Old Jun 30, 2007 | 05:33 AM
  #38
clemlover15
the yellow forged ones, it can make 13 it just can't hold it///
Old Jun 30, 2007 | 06:50 AM
  #39
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Sounds like a boost issue. Do they have a boost log? You could be hitting 13psi, but if you are tapering to 10psi near the power peak, then you only making 10psi, and then the numbers sound right.
Old Jun 30, 2007 | 08:06 AM
  #40
clemlover15
thanks I will be looking into that this thursday,
