Help me out boys Dyno Results F*&^_&!
Old Jun 29, 2007 | 10:37 AM
clemlover15's Avatar
clemlover15
Default Help me out boys Dyno Results F*&^_&!
dyno results, my fuken car with final tune-only made 435rwhp at 13psi, what the F!!!!! Build motor APS TT motordyne MREV, Hiflow cats, AEM EMS,
Guys make that at 9psi???? whats up here....
I do have the APS 2.5" exhaust but still i was expecting more!
400 TQ
Old Jun 29, 2007 | 10:41 AM
stormcrow's Avatar
stormcrow
cats = FTL... remove those and put in some nice 3" downpipes... also, do you have headwork? cams? if not, that sounds about right with cats and 2.5" exhaust... what are your torque numbers? i'll wager they're much higher than your hp numbers...
Old Jun 29, 2007 | 10:45 AM
BrianLG35C's Avatar
BrianLG35C
What dyno? That does seem low, I was at 442whp @ 9psi on a dynapack.
Old Jun 29, 2007 | 10:46 AM
Gumpdriver's Avatar
Gumpdriver
OK get some 2.5-3.0 down pipes and at least some 2.75in -3.00in exhaust.
Old Jun 29, 2007 | 10:47 AM
ht4's Avatar
ht4
It's not entirely the cats. I have 417whp at 8psi with metalic highflow cats, APS 2.5" exhaust, 5/16 spacer, RPS flywheel and APS TT. Of course, I am on a stock block, so the higher compression helps out, but even with cats, that seems a little low.
If you do not already have them (and you insist on running cats -- like me), you might want to try switching to a metal substrate cat... they will flow MUCH better than the ceramic cores.
Old Jun 29, 2007 | 10:49 AM
clemlover15
I have the hi-flow metal cats!!! this sucks !!! I'm selling this ****
Old Jun 29, 2007 | 10:50 AM
clemlover15
dynojet dyno, I just should of keep my stock block for this power, what a disapointment.
Old Jun 29, 2007 | 11:00 AM
craigo'sznprgrs's Avatar
craigo'sznprgrs
only way to rectify. +1000000, and get a new tune
Old Jun 29, 2007 | 11:01 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Hell no!
That does not sound right.
Sorry bro but your tuner sucks. Post the dyno chart so we can see that rollorcoaster. You should be tapping at 500hp @ that PSI.
Old Jun 29, 2007 | 11:02 AM
clemlover15
I have heard of others making a lot more than me with the same set up, I just wanted to touch 500rwhp without a loud exhuast note, and where I live I have to run a cat....
Old Jun 29, 2007 | 11:03 AM
eagletanggreen
Got Track!!!!!
Cats or no cats that is way to low..
Demand a retune or send it to a real VQ tuner.
Old Jun 29, 2007 | 11:04 AM
doug's Avatar
doug
how about a dyno chart with the boost
Old Jun 29, 2007 | 11:05 AM
eagletanggreen
Got Track!!!!!
My car did 410 on Sharif dyno and 450 on a Dyno jet stock block, and with little PE turbos. So built motor with bigger turbos, and more boost... I am sure you can figure it out.
Old Jun 29, 2007 | 11:06 AM
BrianLG35C's Avatar
BrianLG35C
I can't remember where you are in Canada but I'd drive down to Sound Performance in the Chicago area and have them tune it. They specialize in the AEM ems.
doug's Avatar
doug
you can't get frustrated and give up.. there is too many unanswered questions here..
where is the dyno chart?
what gear was it dyno'd in?
what EMS was tuned?
what was the AFR?
Old Jun 29, 2007 | 11:09 AM
eagletanggreen
Got Track!!!!!
what EMS was tuned?
what was the AFR?
+1
Can you post this Data?
Old Jun 29, 2007 | 11:12 AM
clemlover15
I have their AEM and it has not worked all that great for me, it has some issues with cold start and ilde that are some what better, but they tell me that I need to got a cable throttle body to fix it perfect.
I would like to scrap the EMS and get sharif up here and do a HKS for me...
Old Jun 29, 2007 | 11:13 AM
clemlover15
Originally Posted by eagletanggreen
+1
I dont have that right now, the car and all that is about 1 1/2 hour away from me..
Old Jun 29, 2007 | 11:31 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
Hmmmmm Its Not The Aem Sp Just Put Out 500+ At A Low Psi On The Aem
We Need To See Your Dyno Chart
Old Jun 29, 2007 | 11:36 AM
Gman2004's Avatar
Gman2004
+1. Clem how far is SP from you? Just suck up the cost and send it to them especially since you got the AEM from them. I know it sucks considering you've already spent a ton of $, but believe me I tell you from experience, it will be cheaper to just send them your car then to have your current shop trying to fix it. I don't want to jump to conclusions cause there may be something wrong with your car, but if there's nothing wrong your tuner has no clue what he is doing. His name wouldn't happen to be manuel? j/k
