OMG! THE VORTECH IS GONE !!! very well damaged !
Old Sep 19, 2007 | 01:46 PM
  #61
Triji's Avatar
Triji
Wow.... I can't believe all of these issues with Vortech blowers lately. I have 40K+ on my kit with no issues at all, I just changed my serp belt for the 1st time when I did the GTM pulley upgrade as well. My COG is still the original one.
Makes me wonder if there is just a bad batch of blowers out there?... Or if there is something different in their manufacturing process? I have had mine on over a year now and other than a clogged air filter (my bad) which was robbing me of PSI and power I have had trouble free boosting and I have been running the 3.12 since day one.
All I do is visual inspections and make sure the serp belt is tight and the COG belt is loose, change oil (Royal Purple) every 3k miles and run 96 oct fuel.
The last issue I have heard of is G35asian and I saw his blower and it rattled as he turned the blower pulley as well as scraped like in the pics here...
Could this happen from having the COG belt to tight?... I can turn my COG belt at least 1/2 to a bit more where you would almost think it is to loose...
Old Sep 19, 2007 | 02:00 PM
  #62
booger's Avatar
booger
Originally Posted by Hexxum001
Damn, up to 8 weeks? Hopefully it won't take that long. It would suck to be without my G for that long.
You can easily drive it with out the blower on . Just take the oil feed line and put it in the return line and clamo it on . Un hook the IC pipe somewhere between the IC and the MAF pipe and put some cheap free flowing filter on it . If you have bigger injectors ....it may go real rich if you try to jump on it . But the car will be drivable .
Old Sep 19, 2007 | 02:46 PM
  #63
Hexxum001's Avatar
Hexxum001
That's what I was thinking of doing booger but it just wouldn't be the same. GTM is probably going to do some other work on my car while it is there anyways. So I will just have to manage w/o the G until it is ready to go.
Old Sep 19, 2007 | 02:48 PM
  #64
Hexxum001's Avatar
Hexxum001
These issues definitely seem to be happening to newer SC's. Is it a coincidence? Maybe, maybe not. Makes me wonder though. At this point I just want them (Vortech) to fix it right so I don't have this issue again.
Old Sep 19, 2007 | 03:06 PM
  #65
G35asian's Avatar
G35asian
I pray for the same thing. If it goes bad again i'm going turbo for sure.
Old Sep 19, 2007 | 04:38 PM
  #66
Hexxum001's Avatar
Hexxum001
Hmmmm . . . I am in Cali so going turbo is not really an option for me if I want to "appear" street legal. My Vortech has the CARB exemption plaque on it in case I get pulled over and I wanna keep that.
Old Sep 19, 2007 | 04:46 PM
  #67
turismo's Avatar
turismo
Originally Posted by JCstart
Feel my pain guys !!!!
First, I bought this kit one or two months ago....
I put 2300 miles with the kit on my car, out of the box, without any probs... until yesterday...
Yesterday evening, I heard a strange noise that came from the Vortech... a jet plane engine BUT at the idle... normaly the Vortech kit is making a lot of noise at the idle, but not like this...not before...? and the noise went away after few minutes....
Today, I took my car to go to work... and the stange noise was there at the morning start, but more louder....
I took my car out for the dinner, same thing, BUT this time the noise did not get away... and as I drove, it starded to became lounder... I stopped the car, on the side of the road and I simply remove the cogged belt, behind the Vortech... and the 15 amp fuse for the inline fuel pump...
at the end of my working day, today... I remove the air filter from the Vortech and OH MY GOD !!!!
we can see some contact traces between the turbine impeller and the housing... and it is pretty hard to turn with my hand...
I spoke with injected performance today...
We will see...
I will let you know the GOOD or the BAD customer servive I will have....for sure....
man... two months old kit !
I will post some pics later today.... you will see what I mean...
Damn that sucks
Old Sep 19, 2007 | 10:09 PM
  #68
imalazeeass's Avatar
imalazeeass
just out of curiosity, if i remove my filter, should I be able to move the sc fins with my fingers? Is it supposed to move freely like a normal fan?
Old Sep 20, 2007 | 02:13 AM
  #69
Barzten1's Avatar
Barzten1
Either way I wouldn't try to do that.
Old Sep 20, 2007 | 06:45 AM
  #70
G35asian's Avatar
G35asian
Not unless your cog belt is removed since the pulley on the back of the supercharger is what spins that compressor wheel.
Old Sep 20, 2007 | 07:13 AM
  #71
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
FYI guys, all you can do is just remove the SC belt that drives it and drive the car normally with no boost. I know someone who does this on the ATI kit when the belts break and she doesn't have any issues driving it. It may run rich as hell, but the car is driveable.
Old Sep 21, 2007 | 10:55 AM
  #72
Hexxum001's Avatar
Hexxum001
Yup, it'll run rich as hell. I decided to just leave my G @ GTM. I'll make due until it's fixed.
Old Sep 21, 2007 | 11:10 AM
  #73
DMK's Avatar
DMK
+1. but I run 91 all the time. *Knock on wood*
Old Sep 21, 2007 | 12:51 PM
  #74
G35asian's Avatar
G35asian
True, but when the blower is bad why leave it on? Just uninstall it and send it out to get repaired. I don't know about any you, but I want to have boost again asap!
Old Sep 21, 2007 | 12:52 PM
  #75
G35asian's Avatar
G35asian
Your fine as long as you are tuned for 91 and don't beat on your car when it is 110+ outside.
Old Sep 21, 2007 | 12:56 PM
  #76
Jay'Z's Avatar
Jay'Z
Procharger FTW..
Old Sep 21, 2007 | 12:58 PM
  #77
G35asian's Avatar
G35asian
Originally Posted by Jay'Z
Procharger FTW..
Lol, vortech kits did not have any recurring problems like this until now... That is why I bought it last month . If the blower goes out again I will be changing to a different kit.
Old Sep 21, 2007 | 01:00 PM
  #78
Jay'Z's Avatar
Jay'Z
Only joking.. It is a conspiracy all these problems im reading about lately i must say..
Old Sep 22, 2007 | 10:41 AM
  #80
Pun1sh3RZ's Avatar
Pun1sh3RZ
my vortech is making a weird *** noise too, new out of the box on a brand new car. I looked and from what I can see the bolt from the blower is hitting against the pipe (chipping away at the pipe coming from plenum) oh well see what Dave has to say
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
Cashwin
Oct 1, 2015 06:36 AM
FromGtoZ
Sep 20, 2015 03:41 PM
