Need Turbonetics Help....
Old Jun 30, 2007 | 02:31 PM
RED HOT Z's Avatar
RED HOT Z
No Ill try to get one.
Old Jun 30, 2007 | 02:32 PM
failsafe306's Avatar
failsafe306
What's the word on turbo blankets causing failure to the turbos? Especially w/o the water cooling option..
Zridder19's Avatar
Zridder19
Yea if you could snap a few that would be great!!
Zridder19's Avatar
Zridder19
+1
Old Jun 30, 2007 | 02:33 PM
MIAPLAYA's Avatar
MIAPLAYA
Turbonetics is starting to stock some heat blankets or you can find the Boost Logic ones online. http://www.titanmotorsports.com/bolotubl.html
Old Jun 30, 2007 | 02:34 PM
MIAPLAYA's Avatar
MIAPLAYA
Well the more heat you retain in the turbine the higher the thermal transfer to the bearing section and the side affect may be a failed seal. Of course now with the water cooled bearing available it should be a non-factor.
Zridder19's Avatar
Zridder19
I saw that one... Isnt that a bit big?
Old Jun 30, 2007 | 02:35 PM
RED HOT Z's Avatar
RED HOT Z
I heard since you are closing in heat you can cook the seals but I really doubt it. Its seems to me that the actual part the blanket wraps is is more the housing than where the seals are.
MIAPLAYA's Avatar
MIAPLAYA
Not really. The turbine housing on the Z kit is a Kolkelen turbine housing a bit larger then most T3s.
Old Jun 30, 2007 | 02:36 PM
RED HOT Z's Avatar
RED HOT Z
Nope thats the one I got fits perfect!
Old Jun 30, 2007 | 02:37 PM
Zridder19's Avatar
Zridder19
Hmm I might just have to grab that one. Bit pricey
Old Jun 30, 2007 | 04:17 PM
VIZAGE's Avatar
VIZAGE
TN and Seibon VT hood. No problems at all. I like the fact that the VT has vents that just happen to be right above the turbo. You can see all the heat coming out when your at a stop.
Old Jun 30, 2007 | 04:50 PM
Zridder19's Avatar
Zridder19
True, I was actually thinking about that hood...
Old Jun 30, 2007 | 06:00 PM
taurran's Avatar
taurran
I had the turbo blanket for about 6 months before I blew up. I've never had a single issue with the paint or heat causing any issues with the hood. The only issues I had with the hood were due to veilside and the crappy parts they make.
Mattg350z
Oct 2, 2015 06:51 AM
dynamic6er
Jul 22, 2005 07:31 PM
MIAPLAYA
May 9, 2005 07:51 AM
z-ulatr
Mar 20, 2003 06:15 AM
