New Tune On Vortech
Old Jul 2, 2007 | 12:30 PM
zzerotwosixty's Avatar
zzerotwosixty
Default New Tune On Vortech
392 whp and 346 wtq @ 102 degrees ambient temp. 2.87 pulley 10 psi, 550 DW injectors, Walbro pump, HKS air filter.
Old Jul 2, 2007 | 12:34 PM
failsafe306's Avatar
failsafe306
Sweet, who tuned it
Old Jul 2, 2007 | 12:36 PM
zzerotwosixty
UpRev.
Old Jul 2, 2007 | 12:39 PM
failsafe306
What kind of dyno to they run down there? I'm about 5-6 hrs away from Austin...
Do they tune UTEC there?
Old Jul 2, 2007 | 12:42 PM
doug's Avatar
doug
did they use the SS Box or did they reflash?
Old Jul 2, 2007 | 12:44 PM
zzerotwosixty
I think it's a Dynajet. They tune the factory ECU.
Old Jul 2, 2007 | 12:46 PM
zzerotwosixty
SS box came out when I put in the pump and 550s.
Biochem7's Avatar
Biochem7
Regular
Nice numbers! I'll have my Vortech installed soon, but I'm going with UTEC since I have no cruise control. What were your numbers before the Vortech?
Old Jul 2, 2007 | 12:52 PM
zzerotwosixty
Hi Ken, I never dynoed stock. I think stock averages around 240 whp. Out of the box Vortech with no tune got me 330 whp, 339 w/o air filter.
Old Jul 2, 2007 | 12:53 PM
doug's Avatar
doug
good luck with that
Old Jul 2, 2007 | 12:56 PM
zzerotwosixty
You only need cruise buttons for map switching. My other map is valet and I'm to poor to go somewhere that they have valets.
Old Jul 2, 2007 | 12:57 PM
dovla's Avatar
dovla
Excellent!
Any supporting mods? Same OEM MAF? How is torque curve, AFR? Please post dyno sheet. Thanks
Old Jul 2, 2007 | 12:59 PM
doug's Avatar
doug
i meant i don't trust the stock ECU for boosting.. but good luck
Old Jul 2, 2007 | 01:04 PM
zzerotwosixty
Don't have a dyno sheet, couldn't post it if I did. Don't have a scanner, digital camera, cam phone not working right now. AFR is 11.0 from 3K rpm to 7100.
Old Jul 2, 2007 | 01:14 PM
zzerotwosixty
Doesn't matter, they only do FI flashes on the dyno. Too many variances between kits even the same brand. All their mailorder flashes are NA.
Old Jul 2, 2007 | 01:19 PM
zzerotwosixty
Peak tq is at 5400, hp at 6400.
Old Jul 2, 2007 | 01:23 PM
dovla's Avatar
dovla
Why distrust in ECU? This ECU does well on NA. Are piggybacks safer?
It’s just that tuning with stock ECU is new.
Hopefully Jared will post dyno sheet for you. Thanks
Old Jul 2, 2007 | 01:25 PM
zzerotwosixty
I'll be putting it on another dyno in early morning when it's not so hot. Maybe I'll get 400. That's at the Dodge dealer. They'll give me a dyno sheet. That's where I dynoed after the initial install.
Old Jul 2, 2007 | 01:33 PM
failsafe306
The danger is if the MAF voltage maxes out. Piggyback's offset the MAF voltage when tuning fuel.
Old Jul 2, 2007 | 01:39 PM
NS_350GT's Avatar
NS_350GT
How do they read boost?
