vortech 2.87 pulley and 440cc Injectors
Old Jul 4, 2007 | 08:49 AM
Blackbird CPV35's Avatar
Blackbird CPV35
Default vortech 2.87 pulley and 440cc Injectors
I am currently bored with my 3.12 pulley setup and sick of being stuck at a 13.1 so I want to pull the trigger and buy the 2.87 pulley.
I have a walbro and the CJM Stage 1 fuel return along with RC 440cc injectors and UTEC.
on all of my runs, the MPS Data Logger says my Injector Duty Cycle is only at 19.5 % (unless it is wrong) and i think the top feeds are safe at up to 80% duty.
Does anyone on here run this setup or do you think it will be safe for me to run it?
Thanks
Old Jul 4, 2007 | 08:54 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
19.5% doesn't sound right
Old Jul 4, 2007 | 09:03 AM
booger's Avatar
booger
+1
From what Ive read and what my shop has told me , running less than 60% duty cycle at WOT isnt good . He didnt get into why though .
Old Jul 4, 2007 | 09:04 AM
Blackbird CPV35
well heres one of my logs
Old Jul 4, 2007 | 09:44 AM
zzerotwosixty's Avatar
zzerotwosixty
Those 440s should be nearly maxed out.
Old Jul 4, 2007 | 09:48 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
what's your FP @ idle on your FPR?
Old Jul 4, 2007 | 09:57 AM
Blackbird CPV35
~53 psi
Old Jul 4, 2007 | 10:03 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
Originally Posted by Blackbird CPV35
~53 psi
with the vaccum line hooked up? That's high. Which explains why your injectors aren't working as hard.
Old Jul 4, 2007 | 10:18 AM
Blackbird CPV35
crap, i knew i did something wrong lol
i measured my base fuel pressure with the vacuum line in
Old Jul 4, 2007 | 03:15 PM
DMK's Avatar
DMK
What do you mean "stuck with 13.1"?
I know a couple people have 2.87 with 440's and no problems. Timrod is one and he is running the stock Vortech FMU and Aux. Pump.
Old Jul 4, 2007 | 03:34 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I hope he means his 1/4 mile time. If it's his A/F ratio that is not good.
Old Jul 4, 2007 | 03:36 PM
Mr_pharmD's Avatar
Mr_pharmD
13.1 in the quarters.
I have similar setup as yours with 440cc but aam stage 1 return line and I had to use 2 pumps bc I was maxed out at around 400 with only 1 walbro and 440cc. I would suggust getting 550cc.
Old Jul 4, 2007 | 09:07 PM
Blackbird CPV35
yeah thats 1/4 mile times, i have it tuned to ~11.5 AFR across the board
Old Jul 5, 2007 | 03:59 AM
jpc350z's Avatar
jpc350z
Originally Posted by booger
+1
I would think that as long as your fuel system can meet the demand and it just happens to be at a low injector duty cycle then that should be good. Low duty means less stress/heat, greater reliability and longer life?
Old Jul 5, 2007 | 05:24 AM
MUZZY's Avatar
MUZZY
you will need 550cc for the 2.87 pully. also please dont go BOOM
Old Jul 5, 2007 | 10:43 AM
Blackbird CPV35
haha i guess i have to wait then.
and i found out that the injector duty isnt in percent on that datalo, its in MS. Even then it still might not be acurate
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
