What Don't Want To Do On Sat
Old Jul 7, 2007 | 06:48 PM
minus500's Avatar
minus500
Default What Don't Want To Do On Sat
Try do to tighten things up with the Greddy Kit on there. I had to tighten the trans bolts up and it was a pain with the wastegates and exhaust being so close.
Old Jul 8, 2007 | 07:03 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
was your tranny off or motor apart ever where the little bolts would have been taken off ??
Old Jul 8, 2007 | 08:09 AM
Eazzy's Avatar
Eazzy
Converter bolts are definatly a "Loc Tite and torque in sequence" item
Old Jul 8, 2007 | 08:19 AM
MardiGrasMax's Avatar
MardiGrasMax
How much harder is it to remover the AT trans with a greddy kit installed? I plan to to a torque converter upgrade and would rather not have to remove the waste gates etc. From what I can tell with out the TT kit installed it looke like it will be tighter to get to the trans bolts but not a major issue?
Old Jul 8, 2007 | 03:11 PM
minus500's Avatar
minus500
HARD. I had to remove the intake manifold, passengers side wastegate, passenger side exhaust, crossbrace, subframe, driveshaft, etc etc. I don't think you'll be able to keep the wastegate in because there is a trans bolt that is very hard to get to. I would recommend just removing it cause it will make things easier. Let me know if I can help you out any more.
Old Jul 8, 2007 | 03:12 PM
minus500's Avatar
minus500
Yes, I had an SFR trans and converter put in when my motor and turbo kit went in.
Old Jul 8, 2007 | 03:13 PM
failsafe306's Avatar
failsafe306
It would be easier to remove the entire front clip of the car and pull the entire motor/trans out the front. I've done it twice in my garage.
Old Jul 8, 2007 | 03:30 PM
TENGAI's Avatar
TENGAI
+1. Pulling the front clip is a LOT easier than dropping the tranny. Takes a few hours, but is fairly straight forward and can be done in the garage on jackstands...
kyin
Oct 15, 2015 05:54 AM
Depravity
Oct 1, 2015 04:49 PM
