weird noise coming from turbo
Old Jul 18, 2007 | 04:57 PM
andyisphat2004's Avatar
andyisphat2004
Default weird noise coming from turbo
Yesterday afternoon i started getting a weird noise, it sounds like it is coming from the turbo (TN kit). It is almost like a whistle, but it is not constant, seems like it moves with the idle of the car. It goes away after about 10 minutes of driving. I changed my oil 2 days ago and used mobil1 0w-40, i dont know if this has anything to do with it.
Old Jul 18, 2007 | 06:11 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
check your BOV...might be a leak there. They tend to whistle when they leak. Does it go away when you crack the throttle open?
Old Jul 18, 2007 | 06:32 PM
andyisphat2004
nope, goes a little faster when throttle cracked open, but again stops after about 10 mins. it is almost like a chirping
Old Jul 18, 2007 | 08:32 PM
vqturbotec's Avatar
vqturbotec
is it a whistle or a whining nosie
Old Jul 18, 2007 | 08:45 PM
MIAPLAYA's Avatar
MIAPLAYA
Is your oil pressure normal after the oil change? I agree sounds like a leak of air somewhere that closes off with heat..
Old Jul 18, 2007 | 11:47 PM
andyisphat2004
yeah oil pressure is normal, seems like it might take a little bit longer to warm up, but i could be imagining that, previously i was running redline 10w30. it didnt do it this evening, i will try again in the morning.
Old Jul 19, 2007 | 08:07 AM
Ed 718's Avatar
Ed 718
BRAVEHEART
If under boost can be a damage to the compressor and or the turbine wheels. Also the turbo can be out of balance also but if under idle then I'm not sure.
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
samansharif
Sep 25, 2015 12:31 PM
