Injected Performance bringing in the first four digit dyno number: 1016rwhp DD
Old Jul 24, 2007 | 06:03 AM
  #141
r@mon's Avatar
r@mon
Originally Posted by kwame@z1
I find that odd that someone even knows the answer to this question. Since I don't think there are that many people who have achieved these levels of power.
I said that because i see transmissions dying with little power. My concern really isn't why they are failing. Whether it's the gearset or the synchros or the shift forks, i wouldn't want a transmission that i'd have to granny shift. You could pop in much weaker transmissions and as long as you just roll onto the throttle and take a half hour tea and crumpet brake between shifts, they'll probably hold up to the power that 99% of the cars on this forum make.
Old Jul 24, 2007 | 07:14 AM
  #142
failsafe306's Avatar
failsafe306
Originally Posted by r@mon
...and take a half hour tea and crumpet break between shifts...
oh, and fixed
Old Jul 24, 2007 | 08:20 AM
  #143
IIQuickSilverII's Avatar
IIQuickSilverII
being that this is a topic about a 1000whp car i think we are not talking about the 99% of car out there ...but the 700+whp 700+tq cars
Old Jul 24, 2007 | 09:18 AM
  #144
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Originally Posted by SoundPerformance
The turbo that you select is going to be the limiting factor for HP on any motor. A GT47 turbo can only support X amount of airflow which equals X amount HP whether it is on a 2.0L DSM or a 4.2L stroked VQ or a 450+ cu inch big block chevy. If you put the GT47 on all three motors the resulting maximum RWHP will be roughly the same on all three if the turbo is pushed to its limits. The larger motor will make slightly more HP and a ton more torque of course. The HP difference due to the turbo being in a more efficient range of the map and back pressure being less. Obviously the TQ is greater because the extra displacement gets the turbo spooled quicker at a lower RPM. Therefore a supra with a GT47 and a Z with one will ultimately make about the same HP..... Z making more TQ and I believe it is a bit lighter of a car?? correct?? So the Z should win
Now to the question of how much HP the 6 spd Z tranny can handle?? I know the supra one can take 1500. Anyone know the limits of the Z manual tranny??
That's a gross oversimplification. A given engine can only push the turbo so much. Yes you can run higher boost on all three engines, which will push the flow into higher PR ratio areas of the map, but what about the flow part of the map?
This is what I am tlaking about, turbos need to be sized properly for every engine, putting just a big turbo because others "felt small" (quoting the OP here) is next to plain stupid.
Look at the compressor diagram that i put up, this turbo is already TOOO big... and your example of putting this turbo on a smaller engine and it producing power is a huge piece of misinformation.
Old Jul 24, 2007 | 09:22 AM
  #145
IIQuickSilverII
while you posted a lot of knowledgable re: sizing the right turbo, stuff that may or may not translate the same way in practice...here i agree better with what joeshmoe suggested RE the torque converter rather than the turbo being the issue here.....
but explain plz why "...and your example of putting this turbo on a smaller engine and it producing power is a huge piece of misinformation" that is a miss information... 2jz - smaller displacement - can put more whp(with the appropriate boost) with same size turbo.
REGARLESS IT DOESNT AWAY ANYTHING FROM THIS ACCOMPLISHMENT OF A1000WHP Z
Old Jul 24, 2007 | 09:24 AM
  #146
meatbag's Avatar
meatbag
You cant do everything by equations.
Old Jul 24, 2007 | 09:32 AM
  #147
GurgenPB's Avatar
GurgenPB
UltimateSleeper
I was only addressing what was said in regard to big turbos on different engines. It's just not how it works.
And yes, you CAN do almost everything my equations...this is how this stuff was invented... it's just that your equations have to be VERY VERY precise, and in this case they are, I assure you.
In IP's case, OF COURSE there are other things in play...but I assure you, that the compressor sizing DOES have a bit to do with it too.
Old Jul 24, 2007 | 09:45 AM
  #148
GurgenPB's Avatar
GurgenPB
UltimateSleeper
I guess you edited yourpost.
There is a very simple explanation to this.
As long as you are working inside the compressor map boundaries...you will make power.. You want to be as efficient as possible, though. And if you are not, then you crank up the boost more and makeup for it. But, everything else being equal, you need to spin the compressor in it's most optimalsite...period.
Now, some will then say, that smaller turbos won't make power.... Here is what no one understands... a smaller compressor that is properly sizedWILL MAKE MORE POWER, but when you crank up the boost without changing the displacement or the redline (the determinants of the inherent volumetric flow of the engine), the effective flow increases through the turbine housing and it becomes a backpressure bottleneck, not allowing the engine to beath...kinda likeputting a small piping exhaust on a car...no different.
So, whenyou go for very high boost situations, to do it right, you still need to pick an appropriate (almost always: SMALLER) compressor housing, but upgrade to a higher A/R (and/or larger exducer diameter/trim) turbine housing. This is why Garrett gives you 2-5 options for A/Rs for any given compressor. And this is where there are NO good equations, and it's somewhat trial and error. Well, actually there is a way to monitor this very objecgtively and that's EMAP(exhaust MAP), but noone really goes this route for reasons of 1) complexity/cost, and 2) they don't know how to interpret EMAP numbers.
Old Jul 24, 2007 | 09:48 AM
  #149
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Is that 3 or 3.4L stroker engine? I will post my compressor chart that will be completely in line with the results above, and you'll see how well you can predict things with 'equations'.
Old Jul 24, 2007 | 10:08 AM
  #150
IIQuickSilverII
oh man.... lets see... says.. non stroked... and just mentions GT47 no NOS
Old Jul 24, 2007 | 11:31 AM
  #151
GurgenPB's Avatar
GurgenPB
UltimateSleeper
WOw...
My math is DEAD ON.
First, look at the dyno...You can actually tell where the power starts a steep climb upwards... so the engine's boost threshold is right before that, at around 5000rpm.
Now, look at my compressor map, with chandler, AZ elevation of 1240' and about 85 degree temp (a reasonable estimate). THose engines also have high VE's, and I was even conservative and gave it about 2-3% above our engine's VEs with cams. Assume minimal 0.05psi per psi boost piping drop, 1" pressure drop across the intake filter and an above average-high 85% IC effiiency.
This is what I come up with.
See how the map predicts that right around 5000rpm s when you are going ot start making boost?
Overall, you see that since they are at the edge of the map, at around 60-65% efficieny, by going with a small compressor housing and a larger than normal/average turbine housing, it would put closer to the middle of the map, where efficiency for the 5000-7500 rpm range would be between 69-76%, and they would gain literally that much more power.
That's my point in all of this.
Old Jul 24, 2007 | 11:40 AM
  #152
o snap its eric's Avatar
o snap its eric
off topic.... GB your a freaking math wizz, can i pay you to go take my math classes?
Old Jul 24, 2007 | 11:58 AM
  #153
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Haha! Thanks!
It all got started by thinking hard about my PE1420 setup and the notion that it's too small. So, it made me go to the drawing board and really read up on teh subject and make a tool that would allow to evaluate turbos objetively and accurately. This was the end result.
Old Jul 24, 2007 | 12:01 PM
  #154
GurgenPB's Avatar
GurgenPB
UltimateSleeper
OK...was gonna post this earlier..
IP promised to post a full dyno of RPM and torque. where is it?
Again, it's obvious that no one in their right mind would put that turbo on a street car and expect to have a satisfying setup....it's a dragster per IP own admission.
But to really know how well the system is setup, I am sure that all of us want to see an actual, complete dyno plot, with torque, power, RPM, AFR, and possible boost.
No?
Old Jul 24, 2007 | 12:06 PM
  #155
SoundPerformance's Avatar
SoundPerformance
Sound Performance
What turbo would you suggest for 1500 crank HP then? Whether it be a 2.0L or 8L motor?
Old Jul 24, 2007 | 12:30 PM
  #156
IIQuickSilverII
PE 1420 x 4 ( IHI )
Old Jul 24, 2007 | 12:45 PM
  #157
Darton Sleeves's Avatar
Darton Sleeves
Very Nice!!! Congrats...
Old Jul 24, 2007 | 12:57 PM
  #158
__jb's Avatar
__jb
Z + Rear Seat
No?
No.
We want to see it run down the quarter mile!
Old Jul 24, 2007 | 01:04 PM
  #159
GurgenPB's Avatar
GurgenPB
UltimateSleeper
PE 1420 x 4 ( IHI )
Well...that says it all (about you).
Old Jul 24, 2007 | 01:06 PM
  #160
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Originally Posted by __jb
No.
Oh yeah, that too.
