Quick APS Oil Pan Question..
Old Jul 21, 2007 | 09:39 PM
Abishop's Avatar
Abishop
Default Quick APS Oil Pan Question..
What size is the drain plug?
Also,
Does it take the oem crush washer?
I have a small oil leak coming from the plug. If i can get a magnetic plug i will, also, if i can't ill need a new crush washer to get it to stop leaking. Anyone know?
Old Jul 22, 2007 | 05:53 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
Also,
13mm..you should use a new crush washer anytime it is removed..whether it is needed with the magnetic plud, probably will, it all depends on the make of the magnetic plug...
Old Jul 22, 2007 | 07:12 AM
Abishop's Avatar
Abishop
^ thanks, im looking at those project kics plugs, has anyone run them on their aps pan? Also does the oem crush washer size fit the 13mm bolt?
Old Jul 22, 2007 | 07:42 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
abishop.. i had the same problem i just replaced the washer and it fixed it....
dude i was scared that i was leaking oil from the block haha i was so relieved when it was the stupid plug
Old Jul 22, 2007 | 01:41 PM
Abishop's Avatar
Abishop
Was the crush washer the same size as the oem one?
Old Jul 22, 2007 | 03:02 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
should be
Old Jul 22, 2007 | 07:19 PM
Abishop's Avatar
Abishop
^ cool thanks for your help guys, ill be fixing the problem tomorrow.
Old Jul 23, 2007 | 11:20 AM
Abishop's Avatar
Abishop
well, i got to the plug and washer today, it isn't a oem crush washer. it is a 13mm copper washer. oem is 12mm and all i could find were neoprene washers to fit, hope it doesnt leak!
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
kyin
Oct 15, 2015 05:54 AM
