Couple tn questions (again) lol....
Old Jul 22, 2007 | 07:37 PM
freezeg35's Avatar
freezeg35
Default Couple tn questions (again) lol....
Overall im very happy with the performance factor, but since going from the sc to st, ive noticed a few things that pick me a bit and want to know if this is normal.
First is the smell when i pull up to a stoplight. Im assuming its because i dont have the cat, and running on the reflash, but the stink only seems to stick around for a bit, not the whole length of sitting at a light.
Second is the throttle sensitivity, or tip in. I find its a lot more fussy and jarring when im slightly on it and off throttle, its just not as smooth as i had before. Again im assuming that before when i had the ss box i was on stock ecu and injectors when out of boost, and now with the reflash its adjusting for the bigger injectors that i have now, thus causing it to be not so refined.
Exhaust will be here next week, and I see a utec and tune after that.
Thanks.
Old Jul 22, 2007 | 10:06 PM
ramega4's Avatar
ramega4
I get that smell also. it's running a little rich right now so i guess thats why. One question do you get rattle from what seems to be the downpipe. Most of the time it come starts at around 2700-3000 rpm's.
Old Jul 22, 2007 | 11:14 PM
rr_z33's Avatar
rr_z33
im running straight test pipes and i feel like im covered in gasoline when i get out of the car. but is it worht the 400whp...HELL YES
Old Jul 23, 2007 | 06:57 AM
freezeg35's Avatar
freezeg35
I do have a rattle, well not so much a rattle rather than a vibration i can feel in the pedals that starts around 2500 rpm as well and goes away at say 3500. My installer says everything is SOO tight that he thinks its prob. one of the overboost pipes rubbing down there.
Old Jul 23, 2007 | 04:42 PM
freezeg35's Avatar
freezeg35
No one has info on the throttle tip in/out?
Thanks.
Old Jul 23, 2007 | 04:46 PM
Zivman's Avatar
Zivman
Thanks.
everything you are griping about are 100% tune related. Get a proper EMS and tune and those things will be taken care of. Reflash FTL
Old Jul 23, 2007 | 08:26 PM
diwun67's Avatar
diwun67
Agreed, get yourself a good EMS and slightly larger injectors
Old Jul 23, 2007 | 10:47 PM
freezeg35's Avatar
freezeg35
Thats what i was thinking, just good to get a second or third etc.. opinion.
Should i get 440s when i get the utec?
Thanks.
Old Jul 24, 2007 | 01:12 PM
VIZAGE's Avatar
VIZAGE
I'd go ahead and get the 550's instead. This way you wont have to worry about the duty cycle % being high at all.
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
